Easy way to change your differential fluid - see video
Old Oct 25, 2009 | 09:33 PM
JOHNSN10's Avatar
JOHNSN10
Default Easy way to change your differential fluid - see video
i know its best to take the diff covers off but is it ok to do it this way too? my ram has the same rubber cap that the jeep in the video has.
http://www.youtube.com/watch?v=rNdHmpQQJJQ
Old Oct 25, 2009 | 09:37 PM
OlDirtyJohn's Avatar
OlDirtyJohn
that way would work. but i wouldnt recommend it. doesnt let you clean out the metal shavings, get it all the way cleaned out, or visually inspect the inside of the diff.
Old Oct 25, 2009 | 10:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree thats the "cheat method" as the vid says but Dirty is right also. Id rather crack mine open also and check everything also. That way you know whats going on in there.
Old Oct 25, 2009 | 10:09 PM
JOHNSN10's Avatar
JOHNSN10
i saw online that my local parts store has a gasket instead of using that rtv stuff.which is better?
Old Oct 25, 2009 | 10:19 PM
OlDirtyJohn
use both. put a light coat of rtv on the pan so the gasket can stick to it. then another light coat on the gasket. allow it to cure for a couple minutes, then stick it on, and torque to specs
Old Oct 25, 2009 | 10:48 PM
Matt99's Avatar
Matt99
Thats how I do mine...easy as heck, I didnt want to pop it off till after warranty ends in awhile
JOHNSN10's Avatar
JOHNSN10
what r the torque specs for the ram? that royle purple stuff is like $20 for 1 bottle and i need like 2-2 1/2 bottles just for the rear
Old Oct 26, 2009 | 04:51 AM
abarmby's Avatar
abarmby
If you have the stock lsd........I would definately not suggest using that method, for the reasons mentioned above.
Inspection of the clutch pack retaining clips imho, is a must do if the stock lsd is fitted.
Al.
Old Oct 26, 2009 | 07:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Al.
Yeah, we know about those CPRCs dont we?
And JOHNSN10, if you think RP @ $20 a bottle x 3 bottles is alot, try doing RP in your trans and doing a complete flush.
