2002-2005 Double DIN
Over the last couple months I was seeing a lot of questions regarding Double DIN stereo bezels for the 2002-2005 rams. I had found this bezel a long time ago but could not find it again till just now.
Double DIN Bezel
So, for all 2002-2005 owners wanting to use a 2 din stereo, your only options are to fab up a bezel yourself or fork over the money for that one there. i think it would look pretty slick painted with that black wrinkle stuff. just a heads up.
Double DIN Bezel
I unfortunately dont have any pics or that but its just the very top part of that cavity that needs to be cut out because the back of that cavity tapers down so it will not let the DD HU fit all the way to the back. All I did was use my soldering gun with a knife tip and cut the plastic out. I cut the from edge and down the two top corners all the way to the back and removed that top plastic piece out. Then the DD will fit fine.
If anyone needs any aluminum L brackets made so you can mount the DD, just LMK. Ive got metal and bending machines at work. All you have to do is cover the shipping, nothing else.
Waht did you use for a 'reference'? how did you line up the hole on the trim to the opening?just center it and cut both ways I guess?
Trending Topics
I first made mine from SS that it was really hard to drill and it had to be adjusted a bit. So aluminum is really the way to go. But as for marking the brackets for holes, I sat my HU on its side and laid the bracket on it first and marked accordingly. Once I had those two holes marked on each side I drlled and mounted them. Then I slid the HU into the dash and marked those holes that need to be drill also.
OP, not trying to thread jack but if you or anyone else is gong to do a DD, you are going to need to know this also.
Once I had my DD HU mounted in the dash I sat my bezel up against the HU and carefully scribed where I needed to cut. I cut a little to the left and right on the top and bottom and then filled in the "half moons" by gorilla gluing ABS plastic to the back side and then filling them in with bondo and sanding smooth.
