3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
New to the Ram family. Just got a 2008 dodge ram 5.7 hemi and love the truck..have an issue. Maybe you can help me. The vehicle apon acceleration seems like its not gettin power and there is a tinging sound, when I give it more gas it will stop but when going about 45 its starts again. Is that the way the truck is or is something wrong. Had many vehicles befor this but never heard that sound before.
welcome. It is called MDS. sounds funny and low on power when in 4 cyl mode. Try driving in tow/haul mode and see if it goes away. Also, according to the owners manual, they recommend 89 octane for the Hemi engine.
I have used .87 OCT, 89 OCT, 91 OCT . I think it is the 4 to 8 cylinder changes. I wish they would not have done that. I recomendation is put it in tow.
If the problem is with the MDS system (never bothered me though), you can buy a chip that will retard the system or buy different lifters that aree non-MDS,
FF
handheld tuner such as Superchips and Diablo predator allow you to disable the MDS.
You should run minimum of 89octane. hemi's are prone to detonation and serious damage can occur using 87oct.
ok, turned off the over drive and that did the trick, no more jumping aroung or loud tinging noise, with that said how can I get the over drive to work without the noise show. Cant the dealer do something Im losing power when this happens.
