whining noise coming from engine??
Old Oct 31, 2009 | 09:22 AM
  #21
MikeHTally's Avatar
MikeHTally
I think it's whining 'cause it has smelled the cold air and wants to go play.
Old Oct 31, 2009 | 06:24 PM
  #22
V_Scapes's Avatar
V_Scapes
might want to check the alternator.
Old Nov 4, 2009 | 08:53 AM
  #23
05Hemi4auburn's Avatar
05Hemi4auburn
Originally Posted by muddauber5.7
Has your noise gotten any louder since it first started? Mine has stayed the same. I guess I'll start with belt dressing and go from there. Thanks
No, mine hasn't gotten any louder over the past few months. That's why I haven't worried about it. It doesn't sound like a bearing to me, and it only does it for about 5 seconds max, so I don't think that's enough time for a bearing to heat up and stop whining.
Good luck and let us know if you fix it.
Old Nov 4, 2009 | 08:54 AM
  #24
05Hemi4auburn
Oh, and I'm positive it's not coming from the belt. It sounds nothing like a belt squeal.
Old Nov 5, 2009 | 11:01 AM
  #25
labarr2500's Avatar
labarr2500
well, i take back what i said about changing the belt fixing mine. It started again, only a loud squicking now changing with rpm.
Old Nov 5, 2009 | 12:40 PM
  #26
codiac's Avatar
codiac
Mine was the alternator, once I got the belt off, I spun it by hand and could hear it grind. I'd pull the belt off the idler so you have some slack and start turning stuff, see if something sounds "off".
Old Nov 6, 2009 | 06:27 AM
  #27
labarr2500's Avatar
labarr2500
i had the grinding already from the alt. Swapped it with a new one and it stopped. Now it's more of a squicking. I guess it wont hurt to check. i know a new alt can also be another bad alt. thanks
Old Nov 8, 2009 | 10:46 PM
  #28
muddauber5.7's Avatar
muddauber5.7
Used the screwdriver trick for a scope on the alternator and sounded like a very rough grinding inside so I pulled the belt off and the alternator does have a grinding noise inside when spinning pulley. I think you guys are right on with saying the alternator now I wonder if the 7/70 powertrain warranty covers this? Anyone know? Or I'll call dealer tom. Thanks
Old Nov 11, 2009 | 07:39 PM
  #29
Wanderer's Avatar
Wanderer
Mine was the alternator bearing. There was play in the shaft when i pulled on the pulley.
Old Nov 12, 2009 | 12:49 AM
  #30
muddauber5.7
Well I put a new alternator on and I have a louder whine now. So I change the belt thinking just maybe thats it but that did'nt make a diff. When turning the pulley on new alt. there is no noise at all and it is charging bat. fine. So I'm stumped here. I'm going north deer hunting this weekend about 400 miles and wanted to get rid of this noise but I might as well just let it get worse so I can find out whats wrong. I't will probably die half way there!!
