2006 dodge ram 1500 big horn BRAKES question
Old Oct 29, 2009 | 09:05 PM
Dcwhat's Avatar
Dcwhat
Exclamation 2006 dodge ram 1500 big horn BRAKES question
Hey all, like the title says I got the 06 ram 1500 big horn and my brakes feel spongy like I have to push the pedal pretty hard to stop, is this the same on all rams ? Or should I bleed my brakes?? Or should I take it to a dealer ship I still have warrenty
Old Oct 30, 2009 | 07:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would try to bleed them or flushing the lines. Also and depending on mileage now might be a good time to change the pads and go to ceramics also.
Old Oct 30, 2009 | 07:41 AM
Fav40's Avatar
Fav40
My 07' feels better than my Chevy Silverado did. It's almost winter now, but come Spring I'm going with Ceramics up front. Damn brake dust
Old Oct 30, 2009 | 08:21 AM
dirtydog's Avatar
dirtydog
Moderate User
06 has Cearmic pads from the factory.
There is no need to bleed your brakes unless you have opened up a brake line.
You need to take a wheel or 2 off and check the pads for wear. My guess is that they are glazed.
If your rotors aren't shimmying when you apply the brakes and they are not grooved up, you can get away with a simple pad swap.
You likely only need pads up front, but i would check the backs for wear as well.
Old Nov 1, 2009 | 02:30 PM
Dcwhat's Avatar
Dcwhat
I have never disconnected my brake lines for any reason, i will take off my wheels when i get a chance, I have only hit my brakes hard 1 time, but when i brake going down a hill, i would push my brakes let off then push again, like a pump, and the pedal will get firmer which i feel my truck stops better. Any idea, i only have 35,000 miles on my truck.ill take a look at the pads. Also the rear disc brakes do i need the special ratcheting tool to turn the piston, or can i use a C-clamp, to compress the piston.
Old Nov 1, 2009 | 03:25 PM
ThunderedRod's Avatar
ThunderedRod
I know exactly what you are talking about with the pump once and the brakes firm up. I have ebc slotted discs and ebc green stuff pads on the rear. I am looking to change the front to the same set up because I think the front discs are warped.
For the rear pads I used a c-style vise grip and a old pad to compress the pistons back to fit the new pads. The hardest part about my install was getting the old rotors off the rear. The e brake pads hold the rotor on pretty good. I used a mini sledge hammer and beat the **** out of the rotors to get them off. They didnt pass inspection that is why I replaced them. But I dont think I could have reused the rotors if they were still good from all the dents I put in them taking them off with the mini sledge hammer.
Old Nov 1, 2009 | 03:35 PM
Dcwhat's Avatar
Dcwhat
so is the brakes suppose to be like this when i pump it and the pedal gets firmer? Where did you get the c-style vise grips at ??
Old Nov 1, 2009 | 03:41 PM
Dubsport's Avatar
Dubsport
Sounds like you are pumping them up and depleting the vacuum in the brake booster making them inevitably manual brakes...
Old Nov 1, 2009 | 03:45 PM
Dcwhat's Avatar
Dcwhat
well the pedal just goes far down which i dont like it, im just asking if people have this one their trucks, or it is just mine. The pedal stops the same way if i pump it or not. I just a little skeptical because im used to a FIRM brake pedal.
Old Nov 1, 2009 | 04:00 PM
ThunderedRod
I got the vise grips at sears. I dont know if the brakes are supposed to work like are, i just know that i dont like a soft brake pedal and letting off then braking again seems to firm them up.
