What chip do you think is best for performance??
Old Oct 31, 2009 | 12:09 AM
  #21
Midnight Runner's Avatar
Midnight Runner
If you do it right, it's good. IF you do it to hot, it's bad. I do a 200 shot. My system can go to 300 shot, but i wont do that.
Old Oct 31, 2009 | 12:22 AM
  #22
sunstorm_2001's Avatar
sunstorm_2001
WHy, ARe YOu GOing TO A FArm SHow? TO OUt PUll A TEam OF HOrse FRom A DEad PUll.
Old Oct 31, 2009 | 12:24 AM
  #23
sunstorm_2001
The concept of TRUCK is powerful utility
Old Oct 31, 2009 | 12:30 AM
  #24
sunstorm_2001
Do you think about the concept of nitro in a pull off or is it the wheel stand at the start line?
Old Oct 31, 2009 | 09:06 AM
  #25
superdak05's Avatar
superdak05
go with the sct tuner from krc performance, it is a little pricey, but marty is excellent, i am running a modded out 4.7 with a 125 shot of nitrous, sct tuner was the only tuner that would get my truck running correctly, and like most tuners, you can get updates of the web
Old Oct 31, 2009 | 10:24 AM
  #26
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by pickup212
I have an 04 Hemi 120 shot of nitrous and a few Bolton’s. Im looking into getting the comp 273 cams, springs, and retainers but i need a programmer with this setup.
I dont know much about the programmers for the truck but my main concern is raising the rev limiter, the tranny shifting, best combination with the nitrous, and obviously power increase.
Does anyone have a similar setup? And what chip do you recommend?
Here is the thing about your truck (and mine since we both have 04's) If you are going to run that setup you will need a custom tune. So you are going to need a SCT or DSP tuner. But, if you go with either of those you are not going to have trans control, so you won't be able to control the trans shifting like you mentioned you want to do.
Now I have a question for you. What type truck do you have? Short bed, long bed, quad cab, single cab, 4wd, 2wd?
Old Oct 31, 2009 | 11:17 AM
  #27
pickup212's Avatar
pickup212
Your running a 200 shot on SRT ... Not the Hemi right??
Old Oct 31, 2009 | 11:18 AM
  #28
pickup212's Avatar
pickup212
Ya i was looking at those and like everything about them except I cant mess with the tranny.
Old Oct 31, 2009 | 11:22 AM
  #29
pickup212's Avatar
pickup212
I have a 2door short bed 2wd ... Its prob the best truck body to set up for going fast because of weight. Lettle traction problems but there ways to fix that and just learning how to drive it the right way.
So is there another way of playing with the tranny if I went with one of those chips?
Old Oct 31, 2009 | 11:28 AM
  #30
Off_Road_Teacher
You could always try a shift kit or the resistor mod but that will not change your shift points or rev limit so I don't know if that is what you are looking for. The other option which some guys have done is stack two tuners on top of each other. A SC for the shifting and then a custom tune from SCT or DS.
