Still getting a p0307 code
Old Nov 9, 2009 | 08:12 AM
bscill's Avatar
bscill
Default Still getting a p0307 code
I had this fixed about a month ago and just yesterday I got the hesitation again then the engine light came on. Searched the code and p0307 shows on the display. why do I get it again?
Old Nov 9, 2009 | 08:33 AM
BEAR's Avatar
BEAR
P0307 Cylinder #7 Misfire
Old Nov 9, 2009 | 08:55 AM
abarmby's Avatar
abarmby
What type of truck you running?
You need to include what year and engine etc, before we can give you any heads up.
Complete a signature on your account, so we can see what we have to work with.
How did you fix this code originally?
Al.
Old Nov 9, 2009 | 09:38 AM
dirtydog's Avatar
dirtydog
Moderate User
tune-up on plugs are due every 30kmi. Buy cheap copper plugs that are reccomended for replacement NOT the better one's. I'd start there.
Old Nov 12, 2009 | 07:35 AM
bscill's Avatar
bscill
Replaced the coil on cylinder 7 again, still has a bit of misfire. What could it be?
Old Nov 12, 2009 | 08:11 AM
HammerZ71's Avatar
HammerZ71
You check the compression on that cylinder yet?
Old Nov 12, 2009 | 09:52 AM
dirtydog's Avatar
dirtydog
Moderate User
What did the plugs look like? Did you check the gapping on them? Also, I wouldn't rule out the possibility of a clogged fuel injector either.
Old Feb 2, 2014 | 01:34 AM
estevan cazarez 650's Avatar
estevan cazarez 650
Hi i need help.on a 2004 dodge ram 1500 hemi?can anyone.help please ill.appreciated
Old Feb 2, 2014 | 11:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would recommend to perform a compression test on the cylinder that you have the misfire problem. Remember remove only one spark plug. Not both or you will show that you have no compression. A lot of people make this mistake. If the engine is running bad and you know which cylinder is misfiring, Remove the valve cover and inspect the valve springs. You could either have a broken valve spring or a valve seat that fell out the head and is holding the valves open.
