Can someone help me out with the overhead computer?
Old Nov 9, 2009 | 11:19 PM
zclif2601's Avatar
zclif2601
Default Can someone help me out with the overhead computer?
Hey guys I wanna let you know that I don't have a Ram but I do have a dakota and I belong over @ dakota-durango.com/forum and I just purchased a overhead console on ebay from a 2005 ram. I plan on hooking it up to my truck when it gets hear but I would like to know if anyone has a FSM or know what color wires do what. Here is the wire layout I received from the seller:
The computer harness has 4 wires coming from it.
- white with purple stripe
- pink with blue stripe
- red
- black with white stripe
the light pigtail has 3 wires coming from it.
- black
- yellow with blue stripe
- yellow with a faint silver stripe
Thanks for all the help guys!
Old Nov 9, 2009 | 11:54 PM
RubberFrog's Avatar
RubberFrog
What year is your dakota? You have to get a overhead comp from a vehicle running the same com bus. The signals are not analog, they're digital.
I tried to hook my overhead comp (2007) into my buddies truck (2004) and it wouldn't communicate. The plugs were identical. The problem was that we were running different com bus'.
Old Nov 10, 2009 | 12:03 AM
zclif2601's Avatar
zclif2601
I was told it will work because I have a newer dakota 2004. the bus wire on my truck is violet/yellow tracer and only one like this console
Old Nov 10, 2009 | 12:10 AM
zclif2601's Avatar
zclif2601
Im trying to figure out which ones the bus,power,dimmer and dround
Old Nov 10, 2009 | 12:17 AM
05RamMan's Avatar
05RamMan
This what you want? I don't fully understand what your looking for so I guessed. This is the image of console for 05 ram 1500.
Old Nov 10, 2009 | 12:20 AM
zclif2601's Avatar
zclif2601
Originally Posted by 05RamMan
This what you want? I can give you the one for the dakota to if you want it.
Looks almost right! i just need to know which wires do what?
mainly for the computer
Old Nov 10, 2009 | 12:50 AM
05RamMan's Avatar
05RamMan
Still not completely sure what your after,
White/Violet if the Data wire to your computer
Pink/Darkgreen Is the Main power, Turns the console on when your truck is on.
Black/White is ground
and Red is the power from the battery so you don't lose memory.
Old Nov 10, 2009 | 01:05 AM
zclif2601's Avatar
zclif2601
Thats it I think
w/v = my buss wire v/y
B/W= ground my black wire ground
I should have one I splice into dimmer and ignition
Here is a rough thread,kinda old
http://www.dakota-durango.com/forum/...ad.php?t=20030
Old Nov 10, 2009 | 11:52 AM
HemiLonestar's Avatar
HemiLonestar
I might have something for you, I will look when I get home this afternoon.
Old Nov 10, 2009 | 12:05 PM
korby05's Avatar
korby05
Well I have a good question then..sorry if I jack your thread man..So can I take my overhead comp out of my truck since it isn't working and take my uncle's out and plug it in to see if it works...My truck is an 02 with the 5.9 in it and his is an 03 with the 5.9. I think they are the same computer
