Yes, another wheel/tire/leveling thread....
I have the Terra Grapplers. Got them from discount tire. They were cheaper there than ordering them online and then taking them someplace to be installed. A lot of folks on here really like the Cooper LTZs too.
I agree with xill on the powder coating. I have seen silver trucks with black rims and it can look good. But I think on a silver truck the silver rims really set off the tires nicely.
looks like everyone has already chimed in on the tire sizing issue, so i'll chime in on the powder coating... NO! if you had a black truck i'd say sure, but the factory painted/machined wheels match your silver paint perfectly. if it was me i'd leave'em alone unless you're planning to go with a different wheel. if you want to be different, then a better option might be to only powdercoat a section of them. like the centers of each of the 5 spokes and leave the trim on either side of the spoke in the machined finish. that would give it a completely different look while still matching your truck too...
I have yet to see another Ram around here with the same 17's as mine. All the other ones seem to have a flat, I guess satin finish to them.
Thanks again for all the responses fellas, I believe my questions are answered, for now. Now its time to hunt down the right leveling kit, and get it all put together!
Brought up from the dead, I recently in the past month or two bought my boss' old stock 17's off of his 06 4.7L qcsb which are a TOTAL upgrade from my stock 17" steels and I'd say they are the exact same ones you have
so you're not alone, but I do believe they were year specific.
But when I finally get around to saving up the money I'm gona LvL her out and either get 295/70r17 ntg's and stick with my new stock rims or go with the ATX Artillery's (17x9 so the 295's would fit just fine I may even go with 305's or would that be too tall for 2.5" level?) in the black finish. I already converted to 4.56's and am Loving it so far.
Btw any update on what you decided ?
The only problem with a 35" tire on stock rims is bead break, a 35-12.5-17 (or 315/70/17) on stock 17x8 rims is ok if you just do street driving and don't corner hard, but take the risk of the bead breaking when going off-road in an aired down situation and hard turns. Would need a 10" wide rim for safe fit.
It could if you don't have enough backspacing. I have the stock 17x8 rims and with my 295/70/17 NTGs I have about a finger's width between the sidewall and the upper control arm. But they have never rubbed.
I have the same thing Deviate. I'm running the same tire on my factory rim. They haven't rubbed for me. Yeah, you could go to 305"s but if you won't have as much room in the fender wall for suspension flex for say if you're wanting to do a little off roading. The 295"s seem just right for me. Discount tire has good deals on the Nitto's right now too!
