06 Ram fuel pump runs w/o key
Old Nov 14, 2009 | 05:00 PM
mildot's Avatar
mildot
Default 06 Ram fuel pump runs w/o key
Anyone have any idea as to what would cause my fuel pump to run 24/7? I have a 2006 1500 with the 5.7 and about 25k miles on it. The battery was dead so I just replaced it without even thinking about a key off amp draw. Put the new one in and the fuel pump started up just by hooking up the new battery. If I pull the IOD fuse, the pump will stop for about 30 seconds and come back on even with the fuse out. Any ideas? Thanks.
Old Nov 14, 2009 | 08:39 PM
butch1581's Avatar
butch1581
try resetting the pcm.
Is it still under warranty?
Did you try to put the key in and start the truck?
Old Nov 14, 2009 | 11:40 PM
mildot's Avatar
mildot
How do you reset the pcm? The truck is out of warranty by 2 months. It runs and drives fine but when you park it and turn it off, the fuel pump runs until the battery is dead.
Old Nov 15, 2009 | 02:26 AM
tlawre87's Avatar
tlawre87
Just unplug your battery for abour 15 min. That'll reset it.
Old Nov 15, 2009 | 10:43 AM
mildot's Avatar
mildot
Well I had the battery out for at least 15 min. so I assume the pcm has been reset. I can't find a relay for the fuel pump. I was told the relay was an internal part of the pcm? Can anyone verify that. Thanks for the help.
Old Nov 15, 2009 | 10:57 AM
tlawre87's Avatar
tlawre87
Check your owners manual, it'll be in the fusebox under the hood.
Old Nov 15, 2009 | 11:03 AM
mildot's Avatar
mildot
Did that first. There is no fuse or relay listed for the fuel pump.
Old Nov 15, 2009 | 11:29 AM
butch1581's Avatar
butch1581
according to autozone there should be a fuel pump relay somewhere.....its probably stuck "on".......Look under y the tank once, have someone hook up the battery and listen for a realy Clicking shut........
http://www.autozone.com/autozone/cat...&parentId=49-0
Old Nov 15, 2009 | 11:33 AM
tlawre87's Avatar
tlawre87
I just found the part for a 2006 Ram 1500 Fuel Pump relay. You got one, i'd do what butch said.
Old Nov 15, 2009 | 11:39 AM
mildot's Avatar
mildot
Thanks, will start looking.
