Installing a hemi in a 2002 Ram Help!
I have purchased an 07 Hemi engine and tranny from a Ram 2wd and I have a 02 Dodge Ram 4x4. I had the 4.7 and replaced it once already and now realize that they are junk. I got a great deal one this engine and tranny with ecu and wiring and with all of the accessories on the engine.
So I have read some info on this and have a bunhc of questions if anyone can help me out.
1. Will my transmission work with the 07 hemi and what makes the 45RFE and 545RFE different?
2. Will my 4.7 motor mounts work on the hemi? If not whiich ones do I use?
3. I see my computer(s) are different from the 07 will I need to change my cab wiring or can I splice the wires?
4. What exhaust setup will bolt up to this engine? ie headers, y-pipe, cat back?
I am sure I will have more questions, but any help on these few questions will be greatly appreciated.
Yes I was planning on using the transfer case that I have in the truck... I know people have done this conversion so it can be done
It can be done, here's what I know. You should be able to get motor mounts from a hemi truck to use to bolt in the hemi. The hemi should bolt to your transmission. The 5-45 is only different by electronics as far as I'm aware. If you want to stay cheap, just get a set of used manifolds from a hemi and take it into an exhaust shop to get them to put an exhaust on from the manifolds. Then, as far as electronics go, I've heard too many different answers on that one to know for sure. Sorry.
Trending Topics
here is the link to my thread for my hemi swap:
https://dodgeforum.com/forum/3rd-gen...s-as-i-go.html
here is the link to my photobucket account dedicated to the swap:
http://s270.photobucket.com/albums/j...20Dodge%20Ram/
Hey guys, thank you very much for the info!! This is exactly what I needed to know. I am on my way to putting everything in this weekend and wanted to plan for issues or try to anyways before I get started. I will let you know how I make out!
Can be done, yes. Is cost effective, no.
Number one, I don't know why you say the 4.7 is junk. Properly taken care of, it is a solid, long lasting engine. Many people on here have them with very high miles and they still serve them. I personally know two people with over 200,000 miles on theirs. One has relagated it for off-road use in his 4x4, the other still uses it for a daily driver in his Grand Cherokee with 230,000+ miles on it.
Number two, if you KNOW PEOPLE who have done this conversion, seems they would be able to tell you all you need to know...
