BCM question on 2003
Old Nov 20, 2009 | 02:22 PM
Eric and Sue's Avatar
Eric and Sue
Default BCM question on 2003
I"think" the BCM needs to be (checked,flashed?)not sure really, but my power door locks stopped working w/fob and both inside switches.
I was told that only the dealer can "reprogram" to get power door locks working again.
True?
Thanks,
Eric
Old Nov 20, 2009 | 02:36 PM
cheapbeater's Avatar
cheapbeater
try unplugging the battery with the headlights on... it drains all the power out or the pcm or something... worth a shot. it worked for my truck when the overhead wouldnt work. but the overhead is controlled by the pcm, not sure if the locks are..
Old Nov 20, 2009 | 02:53 PM
Eric and Sue
I will try that. I did unplug battery over night,but did not put lights on or rather put headlight switch on.
How long did you leave battery disconnected?
Thanks,
Eric
Old Nov 20, 2009 | 03:00 PM
cheapbeater
half hour
Old Nov 20, 2009 | 03:10 PM
Eric and Sue
half hour
Ijust read that if you disconnect the BCM for 30 sec. it my work also....Where is the BCM located?
Old Nov 20, 2009 | 03:14 PM
cheapbeater
i assume you mean PCM? that is a fuse... i think it's #16 under the hood...
Old Nov 20, 2009 | 03:17 PM
Eric and Sue
I was told BCM...body control module
Old Nov 20, 2009 | 03:30 PM
HammerZ71's Avatar
HammerZ71
yeah, there is a BCM, although I've always heard it referred to as CTM (Central Timer Module).
Could have lost it's mind, rare, but happens. More than likely it will have to be replaced, about a $300 dealer part. Then must be programmed from your vin # based on the electrical features of your particular truck.
At some point I believe they integrated it with the PCM which is the main computer controls the whole vehicle, not sure what year they did it, may be all the 3rd Gens.
In which case you can try your PCM reset, and check fuses, after that, if not working, it's probably call the dealer time...
Old Nov 20, 2009 | 03:37 PM
Eric and Sue
Could have lost it's mind, rare, but happens. More than likely it will have to be replaced, about a $300 dealer part. Then must be programmed from your vin # based on the electrical features of your particular truck...
I have head that too. Do you know where the BCM/CTM is located?
Thanks,
Eric
Old Nov 20, 2009 | 03:48 PM
cheapbeater
huh, i learn somethin new everyday on this site
