Greasing U Joints?
Old Nov 22, 2009 | 03:27 PM
bigdaddyII's Avatar
bigdaddyII
Default Greasing U Joints?
I dont know if my 2002 2wd came with greasable u joints, I am guessing no. If this is the case, my u joints have been changed. There are greasable ones in there ATM, I just cant grease them.
Is there a special fitting to accomplish this. The fitting on my gun is the universial one, but it is straight and it is too tall, it hits the yoke when I try to lock it onto the zerk. Anyone else run into this?
Old Nov 22, 2009 | 03:51 PM
cheapbeater's Avatar
cheapbeater
i've ran into these on ATVs... and ended up buying an angled zerk attatchment, worked pretty slick. i think i got it from the local tractor supply. you tried rotating the u-joint to get a better angle right?
Old Nov 22, 2009 | 04:55 PM
bigdaddyII's Avatar
bigdaddyII
I can only rotate it round and round, which I tried. When I get to work I can try jacking the diff up to angle it but it is a lloooonnnnngggg shot. I will stop by AA or Oreillys and see if they might have something like that angled one. If anything I may just buy some more zerks and install angled zerks. Nah, I will wait until they have to be changed for that.
Old Nov 23, 2009 | 12:10 PM
bigdaddyII's Avatar
bigdaddyII
Okayyyyy, so a 90* dosent work. The front joint I can access with regular fitting. There are no rain clouds overhead so I can finally see decently. The back one appears to be installed backwards, not that I would be able to get to that one if it was installed correctly either. The front one will not take grease. It all comes out at the fitting as I am pumping. The ball in the zerk works too, swapped it out anyway and still wont take grease. I will just leave it be for the rest of it short life and buy some lifetime ones and make bank off of the replacements.
Old Nov 23, 2009 | 03:46 PM
05RamMan's Avatar
05RamMan
Interesting, They must of been changed like you said. Wish mine were greasable, I hate so called lifetime Non-greasable joints. Maybe if you got a picture it would help us to understand what your seeing.
Old Nov 23, 2009 | 06:55 PM
Gone Fishin's Avatar
Gone Fishin
When its time to change the joints out again, check out napa and their Premium line of u-joints. The premiums have the zerk screwed into the end cap, I have this on my front driveline. You pay more, but no more hassles with greasing. Changing out u-joints is a HUGE PIA---I totally hate it, found a better way not to have to do it as often :0)!
Old Nov 23, 2009 | 10:43 PM
sharkhunter10's Avatar
sharkhunter10
its easier to just buy new ones!! I have to help buddy's out them on there Chevy because they tend to squeak on them!! Go figure its a chevy
Old Nov 24, 2009 | 07:31 AM
bigdaddyII's Avatar
bigdaddyII
Gone Fishin, I will definately check Napa out for the ones you are talking about, that would make greasing easier all around. Sharkhunter, I tired quickly of rolling around under the truck knowing that I was pissing in the wind. I will let these wear out and have them changed witht the Napa ones (if possible), that way I can pump them slap full of Mystik JT-6 every time I change the oil. I also looked under my wifes F150, that SOB has 3 joints, no grease fittings. Gonna change those too, which ever truck goes out first, the other will be changed at that time too.
