Regular cab sub box
Old Nov 28, 2009 | 08:49 PM
jpose123's Avatar
jpose123
Default Regular cab sub box
does anyone know if there is a single sub box that will fit inside the tray, or has instructions on maybe removing the front part of the tray directly in the middle to fit a sub box, but keeping a nice clean look? thanks o and the sub i want to use is a kicker solobaric l5 12" square sub
Old Nov 29, 2009 | 12:21 AM
chambers's Avatar
chambers
If it was me I would get a good shallow mount 12" and build a small box for it. You can also buy/build something like this http://www.supercrewsound.com/commer...d=147&catId=65 and put the solobaric in it.
Old Nov 30, 2009 | 10:16 AM
ChaosWarlord26's Avatar
ChaosWarlord26
If you want an L5 then you are going to have to remove the plastic try and build a box. This is required because of the mounting depth needed for the L5.
Old Dec 1, 2009 | 10:24 AM
jpose123's Avatar
jpose123
well can i get a kicker crv 15?
Old Dec 1, 2009 | 10:43 AM
jpose123's Avatar
jpose123
or maybe if i cut out the whole part of the middle to keep part of the tray behind the passenger and driver seats, i only want one sub to.
Old Dec 1, 2009 | 08:36 PM
chambers's Avatar
chambers
Yea, either way it will require some work. Post some pics of it if you go through w/ it.
Old Dec 6, 2009 | 12:27 AM
grayth_55's Avatar
grayth_55
i just built a custom box for my single cab. i had to take out the tray but also i put in two 15's
Old Dec 6, 2009 | 02:42 AM
infinitipearl's Avatar
infinitipearl
i just installed this 2 days ago. it it custom engineered to fit exactly in the tray (even around the hooks, so you don't have to remove them - you can see some of the detail in the picture), and takes up about 65% of the the cab behind the seats. i still have room behind the passenger seat. the company has a great reputation online, and i can understand why. but it does come with its own 10" sub, but it is such a clean sounding sub. it's a ported box. i'm running a kicker 550.3, with 85x2 pushing the front 6x9's i put in, and 420x1 pushing the sub. i absolutely love how it came out.
http://www.proboxrocks.com/products/...00/index.shtml
