Stock Tires
Old Dec 5, 2009 | 12:06 PM
  #51
SilentRamAD's Avatar
SilentRamAD
A big reason for the difference in price between sizes isn't so much the "demand" of the tire, but rather the specs of the tire. You gotta be mindful of the specifications. In some cases the much less expensive tire is NOT a LT (light truck) tire but is rather a P (passenger car) tire and as such will not have the same ply rating or load handling rating of the more often times, more expensive tire within the same lineup.
Also, a "P" tire will often not have near the same tread depth that the same tire in an "LT" will.
The 295/70R17's I was referring to are LT's ^^ I know about the P's typically being the cheaper tire which is why I was stoked and confused at the same time that the 295's were cheaper than it's 285 brother and just barely more than the 265's.
Old Dec 5, 2009 | 03:03 PM
  #52
04 HEMI 04's Avatar
04 HEMI 04
I am no tire expert or anything about tires.
From what i hear 285/70R17 should able to fit in with no problems and it is 33" tall, please correct if im wrong. I can get 265/70R17 easy as simple for stock size.
My tires is getting worse on wet performance.
Which tire size should i go with Nitto terra grappler? FYI, I now travel highway around 80 percent and 20 in city for school.
I went to the town fair tires just for the quote and the quote is 707.66 dollars without the labor i think. It is for 165/70R16. They must be trying to convince me to buy the tires. Not going to happen before i am sure i am getting the right size.
Old Dec 5, 2009 | 03:13 PM
  #53
02Steve1990's Avatar
02Steve1990
I think the Dura Grappler is what you will want if you are doing a lot of highway driving
Nittotire.com
click on grappler trucks and then on Dura Grappler
The Dura Grappler® is a highway terrain tire that provides outstanding treadwear life and ride comfort. Revolutionary Dura-Belt™ 3Steel Belted Technology* reinforces and stabilizes the tread area to reduce irregular wear and improve tread life. The Dura Grappler® will be available in popular 'E' load range, heavy-duty LT sizes for today's demanding diesel trucks. The Dura Grappler® features two distinct sidewall designs so you can customize your look. Tread patterns will vary by size: LT metric sizes are offered in a durable 4-rib design, while P-metric sizes have a quiet 5-rib design. Whether you're working on a construction site or towing your toys, the Dura Grappler® was designed to meet your needs.
*In select sizes
45,000-mile limited treadwear warranty for Dura-Belt* sizes
60,000-mile limited treadwear warranty for P-metric/Metric sizes
Performance Rating: Q R T H
UTQG Treadwear: 600 (P-Metric and Metric Sizes Only)
Traction: A
Temperature: B
Old Dec 5, 2009 | 03:19 PM
  #54
04 HEMI 04's Avatar
04 HEMI 04
I would get dura grappler but i do want more aggressive tread so terra grappler is good enough. I dont know about the size though.
Old Dec 5, 2009 | 03:21 PM
  #55
02Steve1990
you got 17" rims right?
Old Dec 5, 2009 | 03:27 PM
  #56
04 HEMI 04's Avatar
04 HEMI 04
yeah same as yours 265/70R17
Old Dec 5, 2009 | 03:30 PM
  #57
02Steve1990
I have heard the 285/70R17 will fit under stock height like you said earlier, I have been looking into that size also, I don't think there should be a problem.
Old Dec 5, 2009 | 07:13 PM
  #58
04 HEMI 04's Avatar
04 HEMI 04
192 a tires is a lot to me. But ill think about it.
Old Dec 5, 2009 | 07:16 PM
  #59
02Steve1990
I'm sure there will be deals out there
Old Dec 5, 2009 | 10:07 PM
  #60
Drangiz's Avatar
Drangiz
So after reading this thread and up on tires a little bit, I think I have finally deciphered the markings on the tires. I have already gone and gotten new tires for my truck (somehow the tread rapidly wore out on the rear stock tires, the only clue was some sort of black rubbery substance on the ground in a parking lot nearby ). The replacements are BFG All Terrains. The size info is LT285/70R17D1 121R B. Now if I have it right, that means my tires are 32.71 inches in diameter, this could be called 33 inches right and is where that common size comes from?, are 11.22 inches wide and the sidewall height is 7.85 inches, correct? Assuming I got all that right, what does the rest of that info mean? I assume LT = light truck and the load rating is probably somewhere in the D1 121R B part right?
