Steering wheel wobble
how old are the tires? if it still has the crappy stock goodyears on it, that could be your problem...
when i bought my truck it had a wobble and i thought it was due to a bad rack and pinion... turned out to be broken belts in 3 tires!! the wobble went away at higher speeds for some reason...
try rotating your tires (front to back, back to front) and see if it changes any...
mine pulled like a somebitch because the tire with the broken belt was taller...
does yours pull?
could be brakes too...
but i got my money on tires... could be flat sided too...
does yours pull?
Alot of shops will only balance tires and wheels on the back, However, If you have wider wheels you need to balance both the front and back of the wheel. Also tire can be out of round or have damaged belts. Try rotating your tires and see if anything changes, if it does you know its in the tires. If not you know to check other things.
Trending Topics
