Which Cats fit??
Old Nov 30, 2009 | 09:39 PM
Mega-Hemi's Avatar
Mega-Hemi
Default Which Cats fit??
I almost ordered a Magnaflow 23959 because that is what every publication I've found said my truck calls for.
The problem is, when I was under my truck changing the oil tonight I took a look at it. I only have 1 cat, and 2 o2 sensors. Everything lists 3cats and 4 o2 sensors for my truck. Does anyone know where I can get the right part number for my application?
Old Dec 1, 2009 | 11:59 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Just get a high flow cat there like 80 bucks.
Old Dec 1, 2009 | 12:02 PM
dodge15004x45.9
http://v12autoparts.com/index.php?ma...cqpeag5dmmsq72
Old Dec 1, 2009 | 12:03 PM
Mega-Hemi's Avatar
Mega-Hemi
If I was home and had my welder and everything, I probably would. I'm stationd in NJ right now and kinda need something I can "bolt" in place, I'm limited on tools.
Old Dec 1, 2009 | 12:05 PM
dodge15004x45.9
So? get a sawzaw cut it off and find some exhaust bolts from pepboy.
Old Mar 14, 2010 | 03:15 PM
jasonw's Avatar
jasonw
Site Moderator
Why do you want to remove your cat? Everything I've read about the units used on 3rd gens say that they are already very nonrestrictive, replacing them with another hi-flow unit won't supposedly net you anything.
Old Mar 14, 2010 | 04:17 PM
lxman1's Avatar
lxman1
Site Moderator
That's correct. The stock ones flow just fine.
Old Mar 14, 2010 | 04:20 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
If you put on high flows you might throw a code. When I installed my LT's with the high flows I got a code and had to do the non-fouler trick.
Old Mar 17, 2010 | 10:57 AM
Mega-Hemi's Avatar
Mega-Hemi
Wow, this came back from no-where. That was for my '02 5.9, not my '06. Anyway, I replaced the cat because it was getting plugged up. That truck is gone now so I guess it doesn't matter anyway. Thanks for the opinions guys.
