Trannys gone
Old Dec 7, 2009 | 09:25 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by 4matty3
i just had the oil replaced in their about 4 weeks ago and now it was completely gone.
Are you saying that there is no fluid in your trans?
Old Dec 7, 2009 | 09:29 PM
nim81's Avatar
nim81
i too am confused
Old Dec 7, 2009 | 09:46 PM
dodgenitto's Avatar
dodgenitto
Where did you get your trans fluid exchange done?
So if I understand you got a fluid flush about 4 weeks ago and now your trans fluid is leaking excessively under your truck and now you are out of fluid and your trans is slipping???
Did they remove the pan?
Did they put in the proper fluid ATF+4?
Just some missing info on the "entire situation"
Old Dec 7, 2009 | 09:49 PM
Off_Road_Teacher
Agreed, we need more info to be able to really understand what is going on.
Old Dec 7, 2009 | 09:52 PM
02Steve1990's Avatar
02Steve1990
keep us updated on what's going on with the story once you bring it in man, good luck..
Old Dec 7, 2009 | 10:08 PM
HammerZ71's Avatar
HammerZ71
Hmmm....... Pyro just had a tranny service done on a perfectly good working unit, they flushed it and within a week the thing was dead. Now if it were that close to going, you'd think the place woulda said something when they had it open?
Now I'm starting to think maybe a drain and filter change might just be the ticket. Thinkin the flush might just be the devil!!!
Old Dec 7, 2009 | 10:09 PM
Off_Road_Teacher
It wouldn't be the first time that the flush has been the problem. When I do mine on this and my previous trucks I just drop the pan, change the filters and fill her back up.
Old Dec 7, 2009 | 10:14 PM
4matty3's Avatar
4matty3
i got the transmission fluid flushed at my mechanics. i dont believe they removed the pan. now it is leaking all over the bottom. hardly any left .
i didnt think to check the fluid level until it started slipping and the check engine light came on. i just had it done and wouldnt have seen any reason to check it.
so dodgenitto u are right- mechanics flushed the trans oil, now its leaking horribly,very very low trans oil left in it, transmission slipping/burning smell , check engine lights on.
Old Dec 7, 2009 | 10:16 PM
dodgenitto's Avatar
dodgenitto
I will let you know when I do mine next week. I am just draining and replacing both filters.
Old Dec 7, 2009 | 10:17 PM
4matty3's Avatar
4matty3
yeah my dad said to never touch an automatic transmission unless it has very high mileage. my uncle said the same thing, and he use to race stock cars and is very mechanically inclined. we its a hell of a time to tell me now
