Wtf
Old Dec 7, 2009 | 09:59 PM
07QUAD6SPD's Avatar
07QUAD6SPD
New Member
Default Wtf
Took my ram in for warranty work.It only has 13,000 miles on it and the front shocks and tie rod ends were bad.Anyone else have this?
Old Dec 7, 2009 | 10:03 PM
HammerZ71's Avatar
HammerZ71
I blew a stock shock after a weekend of playing a little bit off road with about 7k on them. That's about it, replaced under warranty with no problem.
As for the tie-rods I replaced mine at 19k miles as part of my suspension lift with bigger, beefier ones. There was a bit more play in the stockers that I would have liked already at that time...
Old Dec 7, 2009 | 10:37 PM
DodgeThunder's Avatar
DodgeThunder
Yah I replaced one of my struts at 17000KMs after it was leaking.. I take my truck up some gnarly trails camping though and I had just got back from a weekend trip a few weeks prior so thats what I figured made it start leaking
Old Dec 7, 2009 | 10:40 PM
butch1581's Avatar
butch1581
I had both tie rods replaced under warranty with less than 20,000
Old Dec 7, 2009 | 10:53 PM
aidenhardcore's Avatar
aidenhardcore
My ram has 26,000 miles on it and since day one, the only thing the dealer had to replace before i borught it at 23,000 miles were the all the brakes and roaters. Thats all. Nothing esle
Old Dec 8, 2009 | 07:53 PM
lxman1's Avatar
lxman1
Site Moderator
Mine checked good when my front hub bearing failed @ 19K.
Old Dec 8, 2009 | 07:56 PM
BadHab1t's Avatar
BadHab1t
ill be checking mine again this upcoming weekend when i do my rotors and pads and i hope they check out ok i pulled on em lastweek when i rotated my tires and they seemed ok but idunno if i did it right ...so can anybody give all of us a proper instruction on how to properly check them...it would be appreciated....i just grabbed and pulled?
Old Dec 8, 2009 | 08:41 PM
ramhunter9's Avatar
ramhunter9
thats the IFS for ya . glad i dont have that anymore
Old Dec 8, 2009 | 08:58 PM
DodgeThunder
Check what wheel bearing/ball joints? Jack the tire off the ground.. grab top and bottom and pull alternating.. it shouldnt go in and out at either top nor bottom.. or put a big bar under the tire and pull up using the ground as an anchor for the bar if you have big *** heavy tires, if theres any play then get someone to look and see if its the wheel bearing, or top or bottom ball joint..
Tie rod ends leave the tires on the ground and while someone sits in the truck turning the wheel side to side about an eighth of a turn just past resisance.. while they do that you lay under and see if the tie rod ends have any play.. sometimes its easier to hold onto them and feal for play if its minimal..
Repeat on the back tires
