good underhood ignition source?
Old Dec 9, 2009 | 04:04 PM
snidehockey's Avatar
snidehockey
Default good underhood ignition source?
I'm almost done w/ my EFAN install...I just don't know a good ignition only 12v source to run to the relay. If I ran a wire into the cab then no problem but that seems like a waste of time and wire.
Old Dec 9, 2009 | 04:07 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Cigar lighter. Pretty sure it is a keyed 12v and never really gets used for anything.
Old Dec 9, 2009 | 04:11 PM
RubberFrog's Avatar
RubberFrog
I agree about the cig lighter, but he doesn't want to run a wire into the cab. Start probing your fusebox with a test light....
Old Dec 9, 2009 | 04:15 PM
Off_Road_Teacher
He can jump off the cigar lighter fuse in the fuse box under the hood.
Old Dec 9, 2009 | 05:02 PM
HammerZ71's Avatar
HammerZ71
A multi-meter is your friend! I metered mine out and plugged it in here. It's switched for sure and obviously has enough juice as I've had my fan in since late '06 with no issues.
Here:
Old Dec 9, 2009 | 05:25 PM
snidehockey
nice...thanks guys. it's all done and works great! I also removed the fan shroud and got an aftermarket coolant reservoir just to kinda tidy things up. I deleted the windshield washer to.
Old Dec 9, 2009 | 06:11 PM
hemiguy0302's Avatar
hemiguy0302
I used the same plug hammer did for my lights so the relay can only be triggered with the ignition on.
Old Dec 10, 2009 | 08:45 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What efan did you use. I need to start seriously looking into this.
