just got subs installed
Old Dec 11, 2009 | 08:53 PM
Bass402's Avatar
Bass402
Default just got subs installed
alright, i just got two 10's installed in my quad cab. i used one of those boxes that fits in the little holes under the rear seat. anyways, i pick up my truck and on the way home, i just feel like it isnt loud enough. so when i get to the house, i notice one sub is pounding pretty good, and one of them is barely moving at all. what are the simple things to check for this? if it matters, they are fosgate subs and a fosgate amp. thanks.
Old Dec 11, 2009 | 09:45 PM
02Steve1990's Avatar
02Steve1990
check the wiring, maybe it's just some minor connection issues
Old Dec 11, 2009 | 09:49 PM
oefootball_70's Avatar
oefootball_70
deff check the actual wires running from the sub to the amp.
Old Dec 11, 2009 | 10:00 PM
JoeHemi's Avatar
JoeHemi
Check the ground
Old Dec 12, 2009 | 11:51 AM
Jonhyboi's Avatar
Jonhyboi
What subs did you get?
Old Dec 12, 2009 | 12:03 PM
disturbedgator's Avatar
disturbedgator
if theyre hooked up you might have to change the polarity of the second sub. but depends what ohm they are. more info needed broski
Old Dec 12, 2009 | 12:27 PM
ramhunter9's Avatar
ramhunter9
my thoughts to the tee!
Old Dec 12, 2009 | 02:26 PM
DodgeThunder's Avatar
DodgeThunder
Pick the truck up from getting them installed at a shop? Take it back ****, if your not gonna do it yourself and pay good money for someone to install them right then why start screwing with it now??
Old Dec 12, 2009 | 07:56 PM
Bass402's Avatar
Bass402
i had to leave in early due to prior arrangements, and i dont really have the opportunity to take it back for a couple of days. they are just the fosgate prime series 10's and the fosgate prime 500-1 amp. i will try changing the polarity. thanks.
Old Dec 12, 2009 | 09:02 PM
BadHab1t's Avatar
BadHab1t
dont mess with it take it back make time if you start messing around they might say you did something to it id go back and just say hey....they gotta fix it.....
