squick in front-end
Old Dec 18, 2009 | 10:39 AM
fk1022's Avatar
fk1022
thanks for the help but i checked the spring position and shocks. everything looks fine.
Old Dec 18, 2009 | 10:42 AM
OlDirtyJohn's Avatar
OlDirtyJohn
Originally Posted by jusjay727
did you replace your shocks when you installed the level kit? what about control arm bushings those squeek when they go bad......i also heard if you remove springs and dont put them back in the SAME way they were theyll squeek also......
thats what was going on with mine, drivers side spring was not sitting in the bucket correctly. squeaked like crazy.
Old Dec 18, 2009 | 10:46 AM
fk1022's Avatar
fk1022
i'll check it again just to be sure
Old Dec 18, 2009 | 10:57 AM
BadHab1t's Avatar
BadHab1t
you may have to pull them out to see for sure if they are set in properly....i hate for to do the work again i know its a p.i.t.a but sometimes worth it....
Old Dec 18, 2009 | 11:00 AM
fk1022's Avatar
fk1022
ya i'll check it this weekend. i'm sure there seated right, but you never know.
Old Dec 18, 2009 | 12:33 PM
fk1022's Avatar
fk1022
i just called the place i had it put on at and they said to bring it by and they would look at it and fix anything for free
Old Dec 18, 2009 | 02:17 PM
fk1022's Avatar
fk1022
i took it to them and they showed me that everything was fine, said it could be a bushing going bad. so i'll have to look them over.
Old Dec 18, 2009 | 05:12 PM
BadHab1t's Avatar
BadHab1t
if so buy energy suspension bushings they are the best......and reasonably priced
Old Dec 18, 2009 | 08:49 PM
fk1022's Avatar
fk1022
thanks for the info
