exhaust question
Old Dec 19, 2009 | 07:22 PM
hemi1500usmc's Avatar
hemi1500usmc
Default exhaust question
i plan on running dual pipes out the back, probly 2.5 inch pipes. id like to have true dual pipes ran. besides buying the headers, is there a website or company that makes pre-made kits per specific truck that you can buy without having a machine shop custom make the entire system?
Old Dec 19, 2009 | 08:04 PM
cwboyjohnny24's Avatar
cwboyjohnny24
wow! you started a debate here on DF, hahahaha just kidding. Some people swear there's no problem running TRUE duals, and some say you have to run some sort of x or h pipe for the backpressure or you'll damage the motor. I'm not sure if they make a kit for it, but you can surely have an exhaust shop fab that up for you. Can't wait to see what people's opinions are.
https://dodgeforum.com/forum/3rd-gen...installed.html
Old Dec 19, 2009 | 08:17 PM
cyclone429's Avatar
cyclone429
I don't know of any kits on the market, I would really love a new set of headers, That in it self opens up a bigger debate, some are convinced they help, some will say save your money.
I'm the pro side of a true dual set up, removeing the y pipe and running two muflers just made sense for a work truck towing on the high way.
Down side is finding good quality muflers and a shop that knows muflers..
On my truck, I needed a new 02 sensor, the old one in the y pipe could not be used and the rear tail pipes were fabbed up over the rear diff, The shop did not have a mandrel bender, and at the time, I thought this was ok due to having some back pressure in the ex.
Go true dual, or leave your truck stock, loss of back pressure was never a issue with my 6sp manual, I don't see any gains with my mods until I tow, or hit the highway, Than the ex pays for it self.
Old Dec 19, 2009 | 09:01 PM
draco8494's Avatar
draco8494
im 98% sure they dont make a true dual bolt on kit, gonna have to be custom, and heres some good readin on exhaust may change your mind or confirm ur consensus...http://autolounge.net/tech/exhaust.html
Old Dec 19, 2009 | 09:29 PM
Pyro's Avatar
Pyro
I Beat Tetris
True duals aren't worth the expense IMO, but if you want it the best setup on a Ram is 2.25" with an X or H pipe, and you'll probably need a shop to do it, which will still be cheaper than a kit.
Old Dec 19, 2009 | 09:58 PM
hemi1500usmc
dont true duals actually add to performance whereas running a Y out the back is only for looks and pointless as far as adding HP and watnot towards the engine?
Old Dec 19, 2009 | 10:14 PM
cwboyjohnny24
He's saying to run duals, if I'm right, but to add an x or h pipe to distribute the gases evenly. They do add hp and perfomance, but depending on the size only at certain rpm's. you would probably gain the same as running a cat back with single in, dual out muffler. You're really only talking about a HP or two, not that much if I've read correctly.
Old Dec 19, 2009 | 10:33 PM
cyclone429's Avatar
cyclone429
Here go's my x or H pipe rant....
Thiers no room under a 4x4 hemi to even consider this, yes, a H or X pipe is benifical, how ever,, all ex pipes have to be equal in length, on the a stock hemi, the left ex pipe of the manifold has a bend to fit in front of transfer case, the right is shorter and meets the left ex pipe in a Y.
The disagreement on going to true dual's is that the Y design is the cheaper factery version of a X or Y pipe and by adding a less resstrictive muffler from the cat back will give you a cheaper version of a dual ex.
The flue tank on a 4wd hemi takes up a lot of space, but thiers room to run to mufflers on the side ( not on the flat )
When you have to ex pipes flowing into one in a Y design, the stock ex sytem is all ready unbalanced when the pipes of the manifold are not equal, by removing the Y and going with two stright pipes into two individaul muflers, the engine to move's air out quicker.
The stock mufler is verry restrictive, its more for a sound deading than performance, but a louder mufler will not increase performance.
From my expireances with my conversion, do not ever run one mufler with 2 inlets and 2 out lets ie DYNOMAX ULTRA FLOW... Stay with two muflers.
Old Dec 19, 2009 | 10:38 PM
hemi1500usmc
so ur sayin i can run an X or H pipe off my existing cat? and run a Y pipe off that for dual exhaust? i dont completely get the concept of the X and/or H pipe. if someone could clarify itd b grately appreciated
Old Dec 19, 2009 | 10:46 PM
Pyro's Avatar
Pyro
I Beat Tetris
+1 on what cyclone429 said, with a couple caveats:
true duals aren't worth it, they do increase performance, but not enough to justify the cost of the system. The Hemi runs well on a single 3" into the muffler with dual 2.25 or 2.5" outlets. The most restrictive part of the system is the factory Y-pipe coming off the collectors, if you want to get near true dual performance for a fraction of the cost, get a magnaflow Y-pipe and the catback of your choice. Kits are always overpriced, any exhaust shop should be able to put in a y-piper, muffler, and tips of your choice run any way you want for the same price or less than the price of just the kit.
