More MPG, 05 Ram 1500 5.7L
Old Dec 22, 2009 | 12:05 PM
  #21
chambers's Avatar
chambers
Originally Posted by RIDER
The e-fan, how was the relay wired? Into a thermostatic switch or something?
I used the parts and wiring diagram on this page for mine http://www.fordmuscle.com/archives/2...cfan/index.php. You can also buy the flex-a-lite black magic 180 kit from moesperformance or airram, it comes w/ everything you need and instructions for the install. The flex-a-lite kit is the easier way but it will cost you more cash for it.
Old Dec 22, 2009 | 02:48 PM
  #22
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well guess what I went out and buoght on my lunch break? A 1990 Taurus 3.8 fan for $25 and an adjustable controller for $35.
Guess I got something to do now for the holidays after all.
Old Dec 22, 2009 | 03:37 PM
  #23
espinosafell's Avatar
espinosafell
Where did you get the adjustable controller?
Old Dec 22, 2009 | 03:45 PM
  #24
Frenchy's Avatar
Frenchy
the efan mod is so simple even a caveman could do it.
Old Dec 22, 2009 | 03:46 PM
  #25
chambers's Avatar
chambers
I thought you already had one weed. Let us know how you like it and if you need any help.
Old Dec 22, 2009 | 03:53 PM
  #26
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont think it will be hard installing. The fan wiring itself is simple and the controller directions are easy. The controller I bought at Advance Auto and is Hayden/Imperial electronic fan controller (PN:3647).
Red is 12v constant
Black is ground
Yellow is 12v switched or 12v constant if you want it to run after the truck is off to continue to cool until the tstat shuts it down
Green is the AC override
Orange goes to the fan. Because I have a dual speed fan I will make this a quick disconnect so i can use the lower or higher speed if needed.
Blue i will not use as I dont have dual fans.
So as you can see, thats not hard at all.
Rrider (OP), if you need any help dont hesistate to ask
Old Dec 22, 2009 | 03:57 PM
  #27
chambers's Avatar
chambers
Yea that's the same one I used, shown in the fordmuscle link I posted earlier, I just had to get a separate relay b/c I'm running my fan on high.
Old Dec 22, 2009 | 05:05 PM
  #28
weedahoe's Avatar
weedahoe
Hall of Fame Member
yeah, ive been trying to locate a Bosch relay locally but it doesnt look good. Guess i will have to order one.
Old Dec 22, 2009 | 05:12 PM
  #29
RubberFrog's Avatar
RubberFrog
A bosch relay won't hold up for very long. I run a Stinger SGP38 relay. Much larger and heavy duty. You can find them on ebay for $20.
As far as quick disconnects, if you use them on the high speed side, you may find them fused together when you go to disconnect them.
Old Dec 22, 2009 | 05:16 PM
  #30
RubberFrog's Avatar
RubberFrog
Here's a pic-
