3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have talked to many dealerships around the Atlanta Ga area and all of them say they will but they dont know if its gonna work b/c they havent done one before and they would still charge me $100 even if it doesnt work. Does anyone know the step by step process the dealership people can take so they do it right or is there anyone on this forum that works for dodge around the Atlanta area?
I just wrapped the wire end and used a small flat screwdriver to push it down with the relay. Always meant to take it out and do a better job, solder or something. Never got a round tuit...
Hammer, so all that does is keep the fogs from cutting out when you hit the brights? Any particular gauge wire to use there or did you just pull a piece and use it? Any minimum gauge to stay away from?
