Blew My Subwoofers
Old Dec 28, 2009 | 05:35 PM
Brado34's Avatar
Brado34
Default Blew My Subwoofers
So about a month ago i bought a set of used subs. with a bassworx box and a pheonix gold amp.
they pounded amazingly for about a week untill i blew a fuse.
ive had problems ever since.
the bass was never as loud and then started sounding kinda weird.. yesterday they blew. if i press down on them they sound fine untill near the bottom and i can feel them crackle.
so pretty much i need some new subs. what should i buy?
also. do you guys think this could have been caused by my iTrip i use. it always causes the audio to sound staticy
and my deck doesnt have sub connections..
Old Dec 28, 2009 | 06:35 PM
mike_r's Avatar
mike_r
The static shouldn't affect it. Just make sure that you have good connections to your battery, amp, and ground. Also check the speaker connections. Loose connections can really screw stuff up. The other thing that might have happened is that the amp is too small to drive those speakers and then you turned it up more thinking you could get more. This would cause the amp to distort and will tear any speaker up in no time.
Old Dec 28, 2009 | 07:33 PM
Unperfected's Avatar
Unperfected
use an ohm meter and check the subs, it might be just ur amp, i does sound like it the amp
Old Dec 29, 2009 | 01:31 AM
Jonhyboi's Avatar
Jonhyboi
what kind of amp are you using? do you have any pictures of it?
and if you get new subs.. TYPE R's! haha
Old Dec 29, 2009 | 02:16 AM
dblrnut's Avatar
dblrnut
pheonix gold is top notch more likely blew the sub's. as for new subs i recommend audiobahn sound good and good priced,kicker sub's are good for earth shattering bass
Old Dec 29, 2009 | 05:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can pick up a pair of Kicker (12" DVC) CVRs for 150 shipped. Thats what i use and love them. But I guess it also depends on how deep your box is and how much clearance you have.
Old Dec 29, 2009 | 02:14 PM
dblrnut's Avatar
dblrnut
this is where i use to get my stuff from it is all refurbished but hey its cheap and comes with a warrenty for like 30 days they have kicker comps for like 55 bucks a sub http://www.caraudiodeals.com/
Old Dec 29, 2009 | 02:26 PM
dirtydog's Avatar
dirtydog
Moderate User
loud music means lots of distortion that will heat up and fry the voice coils. Just because you cannot hear the distortion doesn't mean it's not happeneing. Distortion turns into heat for the woofer which will cause failure. This is from excessive volume or a cheap amplifier that is turned up too much. Generally when tuning a system, you raise the HU gain to 80% of max volume and adjust from there. You should never go beyond 80% of the HU volume once adjusted. MOST HU past that amount incurr lots of harmonic distortion not heard by the human ear. When you can hear it..Your speakers will cry murder..We all know what that sounds like...crackle!
if you popped a fuse on your amp, there must be a reason why. it could have been because your subs were already the cause of the problem. never heard of bassworks? My guess is that they were causing OHM related issu'es that caused your amp fuse to pop.
Old Dec 31, 2009 | 06:51 AM
bert6573's Avatar
bert6573
I've blewn two sets of subs in my truck. What happened to me was just a powerful amp. My two cents
Old Dec 31, 2009 | 10:06 AM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
I blew two Memphis subs, the first 48hrs I had them!!!! Brand new too. I contributed to the box I had, but as DD said, it was because I was throwing all kinds of "nasty" power to the subs. Not that my amp is necessarily 'cheap', but the installer (cousin of mine) said that when I crank the amp up like I was, it would actually send out around 1000watts (rated @600w), of distorted nasty power. Blew'em right up.
Type R's are your friend I would say go with the 12's if you can. I like my 10's, but they're still not enough for me. I need more box though.
I saw a set of 12's on ebay, "new in the box", for $240, shipped I believe. Pretty good deal, the 10's sell for $200 each at Best Buy (got lucky and got mine for $100 a piece).
