aftermarket parts
Old Dec 28, 2009 | 06:11 PM
1badhemi07's Avatar
1badhemi07
Default aftermarket parts
ok this might sound stupid but i changed from a 350z to a dodge ram. Dont get me wrong i love the ram. ok so i got a exhaust and got intake and getting the superchip this week what else can i get i want it faster liek parts i can put on then after internals i guess. Also i was thinking supercharger or turbo and 1 reccommend a palce in ny area to do any work. Put in supercharger or turbo or put in a lift kit thanks
Old Dec 28, 2009 | 06:27 PM
cwboyjohnny24's Avatar
cwboyjohnny24
One of the parts a lot of guys on here like to put on are rear end gears. There's a lot of guys with some go fast parts on here, so I know they'll chime in. Post a pic and welcome to DF. Also, on your signature, go ahead and put your truck details and what you've already got on your rig. Just a suggestion for people here to help and not repeat what you've already got!!
Old Dec 28, 2009 | 10:24 PM
OlDirtyJohn's Avatar
OlDirtyJohn
high stall torque converter. check out Edge Racing Converters, Andre over there can set you up with exactly what you need.
other than that, best mods out there are: intake, exhaust, headers, ported throttle body, tq converter, rear end gears (4.10 or 4.56) e-fan, camshaft and heads.
Old Dec 28, 2009 | 10:41 PM
smallkiller's Avatar
smallkiller
What size rear end gear would you recommend for someone who likes to go to the track?
Old Dec 28, 2009 | 11:15 PM
HemiLonestar's Avatar
HemiLonestar
Stroked 6.1! (392, 426 or 440)
Old Dec 29, 2009 | 03:59 AM
06 Ram5.7's Avatar
06 Ram5.7
Well, if you like to go to the track, I would say 4.88's if you have a 2WD or 4.56's for a 4X4.
Old Dec 29, 2009 | 05:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Be careful on the gears because if you get too much gear and small tires its not going to be streetable. I run 2000 rpm with 456s and a 36" tire. So obviously if you are running 456s with stock 20s and a 32" tire or even a smaller rim and tire then your rpms will be higher.
That might not be so bad (MPG wise) in a 4.7 but in a gas thirsty HEMI, you might wanna think about it.
Speaking of which, you have told us nothing about your truck and what wise engine or year it is.
Old Dec 31, 2009 | 02:39 AM
1badhemi07's Avatar
1badhemi07
ok i got a 07 hemi so i would og to the track alot its 4x4 so u think 4.56 would b the best
Old Dec 31, 2009 | 02:47 AM
1badhemi07's Avatar
1badhemi07
nvm i got a great deal 295
https://www.truckcustomizers.com/sec...ut_process.php
