Old Aug 5, 2015, 12:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
2006 1500 4wd problems
Old Feb 4, 2014 | 03:26 PM
jmenter11's Avatar
jmenter11
i know this is an old thread but ...i have the 4WD light flashing on the instrument panel where it would indicate that you are in 4WD not the "serv 4WD" light ...would this be the same issue
Old Feb 5, 2014 | 10:10 AM
rocket23's Avatar
rocket23
It was for me, I needed 4wd lo,(stump pulling) and the flashing light was a tell tale sign , It stayed in 2wd hi........dealer replaced the tipm AND the actuator for 800 bucks.....should a been double that, but they misdiagnosed the issue....Saying the actuator threw off the tipm..........I originally was told the tipm was the culprit.........but it was the actuator all along.
Old Feb 6, 2014 | 09:59 AM
jmenter11's Avatar
jmenter11
great thanks I have an appointment with the dealer to have them diagnose the problem
Old Mar 2, 2024 | 01:22 PM
Savagemoney's Avatar
Savagemoney
Default Transmission 2006
Where is the shift or transmission actuator? 4x4 **** not lighting up stuck in neutral..I tried the whole push N button in but didn't work..when started it grinds when put back into park will not move in any gear? But I hear it trying to do something and fluid spraying out of my transmission blow tube?
Thanks in advance please need back on road asap for work already missed two days
Old Mar 2, 2024 | 05:17 PM
10 year old thread. No information on what you are driving.... Start your OWN thread, tell us what you are driving, and exactly what the problem is, and what, if anything, you have done to find or fix it. Otherwise, we simply can't help you.
Old Mar 2, 2024 | 07:33 PM
Owned like a boss. 🤣
Old Mar 3, 2024 | 08:31 AM
You just wanted to post in a locked thread.
