filter change
Old Jan 1, 2010 | 07:52 PM
stuntpilot's Avatar
stuntpilot
Originally Posted by ramhunter9
yup mobil 1 hear . i did a test one time back a few years had 3 buddies one was using a fram one was using a mopar and i was using a mobil 1. now we all changed our oil and filter at the same time give or take a day we ran them 3k miles. after that i collected all the filters and let them drain overnight . next day took a hacksaw to them .....long stort short im still using mobil 1 filters. and with what i showed them , they are now also using mobil 1 filters
If you use a hacksaw to cut a filter you won't know if the filings came from the engine or the saw.
Old Jan 1, 2010 | 08:36 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I also was going to point that out. They do make a special tool to cut them open though without making shavings.
Old Jan 1, 2010 | 08:38 PM
stuntpilot's Avatar
stuntpilot
Yeh a can opener!!!!
Old Jan 1, 2010 | 08:44 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Are the filings you guys are finding in the filter from your engine the same size as the filings coming from the hack saw? The filings I found in my old truck's filters were always super fine like powder, not like the filings coming from the saw.
Old Jan 1, 2010 | 09:07 PM
stuntpilot's Avatar
stuntpilot
Depends on how much your engine is eating itself! No really you can spot the difference but it could hide other damage.
Old Jan 1, 2010 | 10:03 PM
chambers's Avatar
chambers
Fram's are just not worth the money when you can get a purolator for about the same price and mopar filters are usually either made by champion labs which makes mobil 1 and k&n or purolator. Purolator also makes motorcraft/ford filters but the bypass valve is a different design (thread end instead of dome end) on motorcraft vs. most other purolators. I think the pureone is the best for value and performance.
Old Jan 1, 2010 | 10:42 PM
ramhunter9's Avatar
ramhunter9
these were findings inside and inbeded in the filter i know the difference between shavings and non . besides a lite blow from the air compressior while sawing gets rid of 90% of the crap while sawing . sorry for the miss spelings been drinkin
Old Jan 2, 2010 | 02:59 AM
Ironsleeve318's Avatar
Ironsleeve318
I use Fram ToughGuard and Puralater without problems. It's all hype.
Old Jan 2, 2010 | 03:02 AM
bert6573's Avatar
bert6573
All i use is Mopar oil filters, and no problem here. I've had my truck for two years now with about a dozen oil changes.
