filter change
Old Jan 1, 2010 | 11:27 AM
badfish88's Avatar
badfish88
Default filter change
2004 5.7 hemi just got done reading horror stories on how bad mopar and fram oil filters are and i think im gunna switxxh it to a mobil one or a wix, question is if i drop the filter how much oil will i loose, not all of it i would assume, i was hoping i can just switch em out and top off what i loose.
Old Jan 1, 2010 | 11:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Dont believe the hype. I used fram for years and year on many many different rides and never not once any issues. I used them because my dad used them for year and year (still does) and never once any issues.
However, if you are changing a current used filter with another then expect paybe half a quart at the most but there again, thats what the dipstick is for.
Old Jan 1, 2010 | 12:06 PM
stuntpilot's Avatar
stuntpilot
I always use factory oil filters, no issues so far.
Old Jan 1, 2010 | 12:50 PM
badfish88's Avatar
badfish88
thanx guys and i appreciate it. i think i just had a bad oil change day, the more i think about it, ive always been a castrol guys and never had an oil related problem. same thing with the filters always used fram, the only reason i run mopar is cause walmart sells em. thankx again and happy new year to all
Old Jan 1, 2010 | 02:45 PM
lxman1's Avatar
lxman1
Site Moderator
Fram has little filter media compared to better brands. Their anti-drainback valve (Ford Especially) is crap. I have only used Mopar filters on mine with good luck.
Old Jan 1, 2010 | 06:46 PM
V_Scapes's Avatar
V_Scapes
ive also run the mopar and wix. mostly the mopar lately though and theyve been fine, always come off without a problem.
Old Jan 1, 2010 | 07:13 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I have been using mobil 1 or purolater on both my hemi and the wife's and have never had an issue with either brand filter.
Old Jan 1, 2010 | 07:19 PM
ramhunter9's Avatar
ramhunter9
yup mobil 1 hear . i did a test one time back a few years had 3 buddies one was using a fram one was using a mopar and i was using a mobil 1. now we all changed our oil and filter at the same time give or take a day we ran them 3k miles. after that i collected all the filters and let them drain overnight . next day took a hacksaw to them .....long stort short im still using mobil 1 filters. and with what i showed them , they are now also using mobil 1 filters
Old Jan 1, 2010 | 07:25 PM
TRXHemi's Avatar
TRXHemi
Fram forever and all is good.....
Old Jan 1, 2010 | 07:31 PM
Off_Road_Teacher
You should do the same test with a filter mag on the side of your filter. I tried it on my old 2nd gen and I was shocked at the amount of super fine metal shavings that were captured by the magnet. It was as fine as talcum powder. I have done the same test with this truck and so far, no metal shavings.
