Cranking noise when turning wheel full crank
Old Jan 1, 2010 | 06:53 PM
Brado34's Avatar
Brado34
Default Cranking noise when turning wheel full crank
Title explains it all... It stops if i drive for a little. But its brutal when in reverse. What do i do??
Old Jan 1, 2010 | 07:03 PM
SMKNRAM's Avatar
SMKNRAM
what is a cranking noise exactly?
ramhunter9's Avatar
ramhunter9
you deal with it or fix it !!!!
Old Jan 1, 2010 | 09:41 PM
Brado34's Avatar
Brado34
well i want to know what it is?
should i be worried. like it literally sounds like its going to explode.
cranking noise - sounds like gears are grinding. like spinning but skipping notches. know what i mean?
Old Jan 1, 2010 | 09:46 PM
SMKNRAM's Avatar
SMKNRAM
need more info cause I am not sure what you are describing. does it only do it while truck is moving or will it do it sitting still? does it sound like a tire rubbing on something maybe? is it only in 4WD or both?
Old Jan 1, 2010 | 10:44 PM
ramhunter9's Avatar
ramhunter9
its probably in 4wd and that is normal .
Old Jan 1, 2010 | 11:04 PM
SMKNRAM's Avatar
SMKNRAM
that is what i was thinking!
Old Jan 1, 2010 | 11:16 PM
CarGuyOhio's Avatar
CarGuyOhio
Maybe he is talking about a low power steering pump noise... God knows PS leaks and bad pumps happen to 3rd gens.
Old Jan 2, 2010 | 08:50 AM
Brado34's Avatar
Brado34
my buddie owns a shop and he was saying the 4wd fluid may be low..
no its in 2wd when it happens. maby the dial is just sticking or something.
Old Jan 2, 2010 | 09:18 AM
SMKNRAM's Avatar
SMKNRAM
you know I bet he is right! go check your 4WD fluid and let us know if it is low!
