lifter noise
Old Jan 4, 2010 | 01:21 PM
jdfisher's Avatar
jdfisher
Does your loud "tick" only happen when you first start the truck (collapsed) lifter or after its been idling? A lot of 5.7 hemi's have a dull sounding "tick", a louder tapping sound upon start up might be a weak lifter, i had to have dodge replace all 16 lifter at about 16000 miles due to a weak lifter that could not be isolated. From what i understand is that these hemi's, due to valvetrain geometry have a bit of extra clearance between the valve stem and guide so the valve doesnt bind at operating temp, causing and audible tick at or off idle.
Old Jan 5, 2010 | 04:29 PM
mcon45's Avatar
mcon45
The loud tick only there when i start the truck, i think it's a weak lifter for it does get softer after a while.
Old Jan 5, 2010 | 05:42 PM
dirtydog's Avatar
dirtydog
Moderate User
If you think that's the case, then throw a quart of marvel Mystery oil in the crankcase. Run it for an oil change and see if it clears up. just don't overfill the oil. You would replace a qt of oil with Marvel Mystery oil. in case you weren't sure.
Old Jan 5, 2010 | 07:12 PM
lxman1's Avatar
lxman1
Site Moderator
Or even substitute 1 qt of oil for 1 qt of automatic trans fluid. Very high detergent and if it is a sludge issue, it will help clean it out.
Old Jan 5, 2010 | 07:39 PM
mcon45's Avatar
mcon45
how long do i run the marvel Mystery oil , or tranny fluid before changing the oil again, it's funny brought the truck a little over a year ago, never had this problem until i started putting mobil 1 in , get that.......................
Old Jan 5, 2010 | 08:57 PM
dirtydog's Avatar
dirtydog
Moderate User
An entire oil change.
Old Jan 5, 2010 | 10:21 PM
04HemiGreg's Avatar
04HemiGreg
I haven't thought of asking about the hemi-tick here because I've gotten so used to mine. Has done it at idle since I bought the truck new. Service manager told me it was normal for the hemi so I went with it. No motor issues - 65k miles.
