lifter noise
Old Jan 2, 2010 | 08:57 PM
mcon45's Avatar
mcon45
Default lifter noise
HI, i have a problem with my 06 ram. I noticed a small ticking when the engine was cold , but now the winter is here it sounds more like a lifter starting to fail. It starts off loud and gradually gets softer and goes away. ram has 47,000 miles on it , any suggestions
thanks
Old Jan 2, 2010 | 09:30 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Check out our Ram Section...lots of folks with good advice there....
Dusty
Old Jan 2, 2010 | 09:44 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
It may be the MDS system if you have the Hemi. I will move this to the third generation Ram section,
FF
Old Jan 2, 2010 | 10:04 PM
lxman1's Avatar
lxman1
Site Moderator
Is it a Hemi? Might be the dreaded hemi tick.
Old Jan 3, 2010 | 08:14 AM
mcon45's Avatar
mcon45
Yeh i understand stand the Hemi Tick but sounds like the lifter is partially collasped and the tick goes away as the engine oil starts to get pumpwd through the engine
Old Jan 3, 2010 | 03:17 PM
lxman1's Avatar
lxman1
Site Moderator
Could be a sticking lifter. What oil do you use?
Old Jan 3, 2010 | 06:37 PM
mcon45's Avatar
mcon45
mobil 1 5-20
Old Jan 3, 2010 | 06:48 PM
lxman1's Avatar
lxman1
Site Moderator
Just to rule it out, check for an exhaust leak between the manifolds and the heads. Often if a manifold stud breaks, it will cause an exhaust leak that will seal itself up when the manifolds heat up. They often can tick just like a lifter.
Old Jan 3, 2010 | 08:25 PM
dirtydog's Avatar
dirtydog
Moderate User
Mine does the same thing. Has since 400 miles. it's the valves and has to do with the "hemi tick". if I rev the engine over 1200rpms the tick goes away and will stay away for 20-30sec and faintly start to come back. Does yours do this?
Cold will amplify the situation.
Old Jan 4, 2010 | 11:59 AM
mcon45's Avatar
mcon45
Sometimes the loud ticking is their for 23-30 sec. and other times 2-3 sec, or not at all,
