2002 V6 3.7L Cyclinder 1 won't fire
Old Jan 3, 2010 | 05:18 PM
Mr. Serpent's Avatar
Mr. Serpent
Default 2002 V6 3.7L Cyclinder 1 won't fire
Cylinder 1 won't fire. I swapped plugs and moved coil packs around but no matter what Cyl. 1 does not fire. It has a very rough idle and a stutter until about 1500 rpm or so. When ever i remove the plug it's wet with gas.
Old Jan 4, 2010 | 01:05 AM
Twink's Avatar
Twink
try hookin up a code reader, see if its throwing more than a misfire code. Thatd be my first start, or check to see if cylinder 1 is even getting spark. if it isnt go from there
Old Jan 4, 2010 | 04:53 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
that's nut. maybe it's just in the ecu. unhook battery for a while, reconnect, see what happens.
the fact you switched coils and plug around kinda eliminates the idea of a bad plug/coil. hell, follow that wire and see whats up maybe...
Old Jan 4, 2010 | 12:36 PM
Mr. Serpent
I pulled the the coil pack and put in a spark plug then i started the truck. Held it close to ground and it sparks just fine but it won't when it's in the cylinder.
Old Jan 4, 2010 | 01:35 PM
chambers's Avatar
chambers
Have you done a compression test on that cylinder?
Old Jan 5, 2010 | 06:24 AM
Mr. Serpent
No not yet, that was my next move. It only has 98,000 miles on it what's the chances of a burnt valve?
Old Jan 5, 2010 | 12:33 PM
chambers's Avatar
chambers
Well it's not really a recurring issue that I've seen on the forums w/ the 4.7/3.7's but it's possible, problems w/ the head gaskets are more common.
Old Jan 5, 2010 | 12:43 PM
Dodge_cowboy2004's Avatar
Dodge_cowboy2004
my number 6 stop'd fireing before...unplug over night...
Old Jan 17, 2010 | 02:01 AM
deathlordjon's Avatar
deathlordjon
try looking at them post that sit on the spark plug. they tend to crack just because they're plastic. if you do find a crack just wrap it in electrical tape and it should be fine
