Hemi engine stalls at stops
Hello;
I have a 2005 Dodge ram 1500 with a 5.7L Hemi. It will crank without any hesitation and accelerate/decelerate with any problem. I come to a stop and the RPM's will decrease from the normal 700 and stall out. It does not happen all of the time and engine temperature does not matter. I was told that it is the Idle Air Control Valve, but no one that I have talked to knows where it is located at on the engine. I have even had a Dodge Mechanic state that there is not one on that engine; but I have had parts dealers tell me that they have sold that particuliar part to people. If anyone knows where it is locate, if I do indeed actually have it on my engine, then I would greatly appreciate it if you could inform me.
Thanks
Thanks
Yeah, I had this same problem happen on my 02 4.7 and it turned out to be a bad battery. The truck cranked over fine but would stall sometimes when I came to a stop or came to a stop and shifted to reverse. Replaced the battery and it didn't stall for a while then started doing it again after a couple months. Replaced the alternator because it was only charging at like 12.5v at idle. Now its been fine for like 3 months. As far as the idle valve on that truck I don't know. Usually if it has throttle by wire (no cable) it won't have a IAC valve but thats not always true. I'm sure somebody will chime in about that.
Had this exact same problem with my 05. right after i took it in for a tranny service. Took it into the dealer and come to find out the place that did my tranny service didnt fill my tranny fluid correctly they were 4 quarts low
Cost me 100 bucks for the tranny service and another 90 at the dealership to tell me they screwed it up!!! Went back to the service place and told them what happened, showed them the bill from the dealership. They bad the dealership the 90 and refunded my 100 bucks for the inconvience they caused
so maybe check and see if your tranny is a little low???
