3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
mounted my hellas a month ago and finally had a chance to wire them up today. it didnt go so well. i decided to wire them directly with 14 wire and a 30 amp switch, but as soon as i got done wiring and flipped them on the wire started smoking and melted, not just part of it but all the wiring melted. dont know what i didnt do right? had the wires hooked up right, lights were grounded to the frame. any help would be great!
Obviously something shorted, How did you have everything wired? Any relay or just battery to switch to lights and the other side of the lights to ground?
no relay. 3 prong switch. pos. neg and load. battery to the power side, ground was grounded and i had the lights hooked up to the load tab. thats how its suppose to be isnt it?
Yeah, thats right. You dont need the ground unless you want the light in the seitch to come on. With one set of the lights wires going to the load side of the switch, you have the other set going to chassis ground right?
Throw a fuse in there first so you dont melt wire next time.. I cant remember how to figure out what fuse to use though, first time i wired up ext. lights I didnt put a high enough amp fuse and after having the lights on for 30 mins straigth it would always pop for some reason..
well, i wired my hellas for a second time today and they work perfectly. dont know what i did wrong the first time, but they work fine now. thnx for the help guys!
