Cold weather shifting problem???
Old Jan 7, 2010 | 07:56 PM
williebyrd's Avatar
williebyrd
Question Cold weather shifting problem???
My '06 will not shift into O/D after it reaches operating temperature. The past few mornings leaving work after about 15 miles I pull over, put the truck in Park, then shift back to drive and it shifts normally into O/D. Anyone have this problem or idea of what the problem may be???
Old Jan 7, 2010 | 08:12 PM
lxman1's Avatar
lxman1
Site Moderator
Mine won't go into 5th until the trans fluid temp reaches a certain temp. Then sometimes you have to let off of the throttle slowly to get it to shift. 15 minutes is a little long though.
Old Jan 7, 2010 | 08:17 PM
williebyrd's Avatar
williebyrd
I travel 30 miles from work to the house and if I don't pull over it will not shift the entire trip during cold weather.
Old Jan 7, 2010 | 08:23 PM
2008 ram 1500's Avatar
2008 ram 1500
My 08 does the same thing. When the engine warms up it goes in o/d. I thought it was normal but then I've only had my truck for a few weeks.
Old Jan 7, 2010 | 11:45 PM
02WhiteRam's Avatar
02WhiteRam
my truck has started shifting weird the past two days also. Mine is also fine when its cold, but once it warms up it acts up.
Old Jan 8, 2010 | 01:47 AM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
mine does the same thing.
