Tune up question?
Old Jan 9, 2010 | 04:31 PM
hoss67's Avatar
hoss67
Default Tune up question?
Does it really matter what spark plugs you use and wires for performance, I am not very knowledgeable on this subject
Old Jan 9, 2010 | 05:04 PM
dirtydog's Avatar
dirtydog
Moderate User
You don't need to replace wires/coil packs unles they are bad.
As far as plugs go....Basic copper plugs every 30kmi.
Don't do fancy plugs..These engine's aren't designed for them although you may not have issue's, Chrysler suggests copper for a reason. Plus they are only $2 per plug.
Old Jan 9, 2010 | 06:36 PM
lxman1's Avatar
lxman1
Site Moderator
^^ what he said
Old Jan 9, 2010 | 07:19 PM
rtmtrrdr's Avatar
rtmtrrdr
I put split fire platinum plugs in my 4.7 and it runs like a screaming banshee.I'll buy them again for sure.
Old Jan 9, 2010 | 10:12 PM
hoss67's Avatar
hoss67
Alright thanks, i just hear all these different type of plugs and i really just wants whats best for my truck and if its copper plugs for 2 bucks then great
Old Jan 9, 2010 | 10:32 PM
matthewbeard's Avatar
matthewbeard
NGK's work great and they are cheap. like stated before the only time i had to change a coil pack was when i was getting a constant misfire from cyl #1 and plugs and wires didn't fix it. the coils are spendy too
Old Jan 10, 2010 | 12:21 AM
lxman1's Avatar
lxman1
Site Moderator
Champion or NGK V-power plugs. The rest are a waste of money. New plugs almost always run better than old ones!!
Old Jan 10, 2010 | 03:52 AM
wyseguy77's Avatar
wyseguy77
Just put NGK Iridiums. Truck runs so smooth I couldnt believe it. Expensive though about $7 a plug.
Old Jan 10, 2010 | 09:36 AM
Flying Mullet's Avatar
Flying Mullet
Anyone try out the E3 plugs?
Old Jan 10, 2010 | 09:52 AM
BEAR's Avatar
BEAR
I assume you are talking about the E3's for a 4.7?
Because its ridiculous how many times its been said on here that the basic copper plug, Champion or NGK V Power, is the best plug for the Hemi. You spend 7-8 bucks or more for 16 of anything else your just wasting your money.
