Fill up problem!
Fill up problem!
everytime that i fill up my truck all the way till the handle on the pump clicks off, when i go to drive away the truck will shut off after driving like 50feet or if i sit at the pump long enough it will shut off and when i go to start it back up it just turns over for good amount of time unless i pump the gas pedal... this started happening about 2 weeks after i got my DSP didnt mess with any fuel or spark and i run 93.. what the hell could be the problem
The only nreason I suggest pulling the DSP off is because you say it started shortly after you put it on. With my SC, I once had a tune and my cruise wouldnt work. Everyone tolde me it wasnt the SC causing the issue but why is it after they came out with a newer update and I used it my cruise worked and never has had an issue since. So thats why I say to pull the tuner off
