Automtic Trans. Shifter
Old Jan 13, 2010 | 01:17 AM
Rikker's Avatar
Rikker
Default Automtic Trans. Shifter
Hey Guys,
Just recently I've been noticing the amount of play/movement that my shifter has while in gear which is fairly significant. Is this common? '08 1500 4x4
Old Jan 13, 2010 | 01:20 AM
Shiloh 24's Avatar
Shiloh 24
It shouldn't be loose at all, the shifter should basically lock into place once you put it in gear. Is it stayin in the same gear when you move it? If it is you prolly just need to tighten it up.
O btw welcome to the forums, too bad you had to have a problem before ya came to see us though.
Old Jan 13, 2010 | 01:22 AM
Rikker's Avatar
Rikker
yeah, it stays in gear. is it an easy fix?
Old Jan 13, 2010 | 01:29 AM
Shiloh 24's Avatar
Shiloh 24
Idk how easy it will be as I have never heard of this before, but if I'm not mistaken the shifter uses a cable to shift gears and you could prolly tighten up the cable. I would take it to a shop or the stealership if I were you just so you don't get it too loose or too tight and have it shifting into the wrong gear or something.
Old Jan 13, 2010 | 01:35 AM
Rikker's Avatar
Rikker
It's got lots o'warranty left, that's the best bet. I'll let the the pros handle it for sure! Thanks Shiloh 24!
Old Jan 13, 2010 | 01:46 AM
Shiloh 24's Avatar
Shiloh 24
Not a problem I'm glad I could help.
Old Jan 13, 2010 | 07:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive never seen anyone report a loose shifter either. Thats interesting.
