Red Blinking Light truck wont turn over
Old Jan 14, 2010 | 07:02 PM
zimm's Avatar
zimm
Default Red Blinking Light truck wont turn over
My 03 Ram has this red blinking light which im assuming is security but when i go to turn the key over the truck wont even turn over and this light just blinks is there anything i can do to get it outta protection mode or whatever its doing??
Old Jan 14, 2010 | 07:08 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Do you have an after market alarm? I'm gonna assume you don't have a key fob. Sometimes if it's an aftermarket alarm, they put somewhere under the dash a valet button. Mine when you turned the key to the first position and pressed the button at the same time it would disable the alarm manually. Maybe other thing you may be able to do is look on your starter and/or fuse box and see if there's a wire going to an alarm box and take it off.
Old Jan 14, 2010 | 07:20 PM
zimm's Avatar
zimm
Ya i had a alarm starter put in it but the alarm/starter isnt hooked up right now and the i dont have a factory key fob because im assuming this truck has no factory alarm
Old Jan 14, 2010 | 07:21 PM
JoeHemi's Avatar
JoeHemi
I had the same thing....just meant the battery was dead. Replaced the battery and all was good. Take a look in the little battery fluid checker on top of your batter and see if theres anything in it. Chances are there isnt.
Old Jan 14, 2010 | 07:27 PM
zimm's Avatar
zimm
well the truck had lots of power wasnt dead but the battery cable wasnt tight. The thing is i just got a different immobilizer put in the truck because the guy that did the command start broke it some how... so i got a used one and its the same as my old one.... so im just wondering if it has anything to do with it.... But even if your battery is low it wont even try to start?
Old Jan 14, 2010 | 07:46 PM
cwboyjohnny24
So you got it to start? Yeah, even if the battery is real low, you should still hear a clicking from the starter.
Old Jan 14, 2010 | 07:57 PM
zimm's Avatar
zimm
thats what i thought but i got nothing yet it still wont even turn over
Old Jan 14, 2010 | 08:24 PM
cwboyjohnny24
All you should need on the starter is the main wire, and the one from the ignition. Any other wires, I would take off and see what happens. You may also try taking the positive wire off the battery and replacing it, and see if that resets the system. Just a thought.
Old Jan 14, 2010 | 08:50 PM
zimm's Avatar
zimm
Ya i ttok the negative off for like half hour at least and came back out it on and same thing
Old Jan 14, 2010 | 09:02 PM
cwboyjohnny24
You should find the computer box for the alarm system and take it out.
