Any idea whats causing this???
Old Jan 15, 2010 | 03:53 PM
NJFF5860's Avatar
NJFF5860
Default Any idea whats causing this???
Drove to work this AM everything is fine! Leave work this afternoon and the truck seems to be wanting to skip across the road (front) when hitting rough areas on the roadway. Also between 60 and 70mph the truck has a shake / Vibration to it to the point you can see things on the front seat shaking, not very badly but you can feel it and see the items on seat shaking. Any ideas guy's? Just had tires put on 2 weeks ago and everything has been fine up til now. Stopped at the place I had them installed before coming home and they are balanced correctly and everything with them is fine. Didn't hit any potholes or anything at all for that matter. Don't understand how something can go wrong just sitting in the parking lot! Thanks in advance for any ideas what this could be 07 Ram Quad Cab 5.7L
Old Jan 15, 2010 | 03:57 PM
fk1022's Avatar
fk1022
alignment...
Old Jan 15, 2010 | 04:22 PM
Shiloh 24's Avatar
Shiloh 24
Mine does that to some extent as well, but more when I get closer to 80mph. I got it aligned and it stopped skippin around when I hit like transitions from roads to bridges and such but it still shakes a bit?
Old Jan 15, 2010 | 04:45 PM
Scorpio_08_HEMI's Avatar
Scorpio_08_HEMI
Improper balance is very likely. Doesnt matter what they told you. As mentioned above , I would have the alignment checked, but its more than likely the balance.
Old Jan 15, 2010 | 04:51 PM
rcman0056's Avatar
rcman0056
The driveshaft connections may be wearing and coming loose but not likely on your newer rig. After you got new tires did you get a front alignment?
Old Jan 15, 2010 | 05:11 PM
NJFF5860's Avatar
NJFF5860
No alignment after new tires were installed but will have it done on Weds during the time the leveling kit is installed! Hope that takes care of it! Just don't see how it could of went out of alignment just like that. If it was a suspension issue, I really want to get it back to the dealer (still under warranty) before getting the leveling kit installed! You know they will say that the leveling kit is the issue!
Old Jan 15, 2010 | 05:36 PM
HammerZ71's Avatar
HammerZ71
My first guess would be alignment as well, but if the place that balanced the tires and checked them didn't road force balance them, then they could still be out of balance when actually driving...
Old Jan 15, 2010 | 06:42 PM
NJFF5860's Avatar
NJFF5860
Well, majority is alignment so I guess I'll wait until wednesday when they do the alignment on it after they install the leveling kit and see what happens! Thanks guy's
Old Jan 15, 2010 | 07:20 PM
Marx's Avatar
Marx
this my be dumb but make sure all the lug nuts are tight
Old Jan 15, 2010 | 07:34 PM
NJFF5860's Avatar
NJFF5860
first thing I checked Marx...thanks!
