HELP!!!! 08 Quad cab Rear U-joint
Old Jan 16, 2010 | 11:36 PM
vmk69's Avatar
vmk69
Default HELP!!!! 08 Quad cab Rear U-joint
Can anyone help me find a rear U-joint part number for a 2008 Quad cab 2500HD? Single shaft. So far my only option seems to be the dealer on Monday.
Thanks
Old Jan 16, 2010 | 11:46 PM
HemiLonestar's Avatar
HemiLonestar
Monday is MLK day, sure they'll be open? PM sent.
Old Jan 17, 2010 | 01:32 AM
05RamMan's Avatar
05RamMan
4wd or 2wd? What engine? Which Tranny?
Old Jan 17, 2010 | 02:22 AM
mmstar23's Avatar
mmstar23
what 05RamMan said, also dunno if it matters, but if its a Long bed, that might be something to state. I would think the dealer would be open monday, im pretty sure its just government facilities (post office, school) will be closed. dont think a dealership would be
Old Jan 17, 2010 | 07:59 PM
vmk69's Avatar
vmk69
Sory duys, it is a 4WD 2008 Quad Cab(they di not make a long box in 08). I'm in Canada so MLK day is a working day. I was hoping to get one before I had to limp to work. Oh well, I tried. Thanks for the responses!!!!!
Old Jan 17, 2010 | 08:01 PM
vmk69's Avatar
vmk69
Wow, I can't type or proof read. Sorry again Everyone.(I checked my spelling this time).
vmk69
Old Jan 17, 2010 | 08:19 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I would disconnect the drive shaft from the tranny and run 4wd, it will make your front tires drive the truck, but it will get you there. I would be at the dealership tomorrow. Just a post to help.
Old Jan 18, 2010 | 03:20 AM
HemiLonestar
Didn't even see you were from CA. Hope the manual helped!
Old Jan 18, 2010 | 07:54 AM
Lifted4x4Astro's Avatar
Lifted4x4Astro
Can't do this. The rear driveshaft has a slip yoke into the t-case. You pull it out and all the fluid will be pumped out while driving. Then you will need a new t-case as well as a u-joint. If it was a fixed yoke, then yes this would work.
Old Jan 18, 2010 | 08:26 AM
cwboyjohnny24
used to playing with my old jeeps. Just taking a stab in the dark. Appreciate the info though.
