Help
Old Jan 22, 2010 | 04:16 PM
bigdan05's Avatar
bigdan05
Default Help
i have an 05 dodge ram 1500 i was at the store last night and i went to crank it up and the battery wasnt dead it was making a clicking noise and after holding it over for a minute it cranked!what could be the problem?or has someone else had this same problem?
Old Jan 22, 2010 | 04:20 PM
Brokenpath's Avatar
Brokenpath
Starter.
Next time that happens hit your starter with a hammer. If it starts immediately after that then that's for sure your problem. They're relatively cheap and easy to replace.
Old Jan 22, 2010 | 04:21 PM
nateroach's Avatar
nateroach
first thoughts would be loose battery terminations, then check starter solenoid, then the starter itself.
Old Jan 22, 2010 | 04:24 PM
bigdan05's Avatar
bigdan05
all the gear lights were on to like the p,r,n,d,2,1 were all lit up at the same time the all had squares around them
Old Jan 22, 2010 | 04:45 PM
cwboyjohnny24's Avatar
cwboyjohnny24
In my experiences that I've had with older cars if it clicks, it's trying to get the starter to turn over, the battery just doesn't have enough juice to kick it over. It doesn't take much battery power to light up the gear selection on your dash. I would have the battery tested.
Old Jan 22, 2010 | 04:58 PM
bigdan05's Avatar
bigdan05
the battery is a year old and sometimes when i turn my turn signal on it wont come on at all or if i turn the left on the right comes on
Old Jan 22, 2010 | 05:47 PM
Matt99's Avatar
Matt99
that sounds like wiring. Are you the original owner? Any previous problems? how long has this blinker problem been happening?
getting your battery tested is free and easy. You could do that on the way home one day, but with the turn signal problems, it sounds like a short or something to me
Old Jan 22, 2010 | 09:14 PM
cwboyjohnny24
It's either the battery or the alternator not putting out enough voltage to completely recharge the battery. Have both checked. Just my opinion.
