Just leveled the truck. CV angle opinions? pics
Old Jan 24, 2010 | 08:03 PM
cheapbeater's Avatar
cheapbeater
just have to wait and see i guess...
Old Jan 24, 2010 | 08:04 PM
rochefort978's Avatar
rochefort978
Originally Posted by oefootball_70
Thats all I am going to say about that.
As far as the CV joints I have no idea. I dont have them.
I posted pictures of the angles (which if you read is what i asked about) and I couldn't get a shot of the whole truck in my garage and its pouring down raining outside.
Old Jan 24, 2010 | 08:25 PM
SMKNRAM's Avatar
SMKNRAM
Originally Posted by rochefort978
Okay I took measurements.
Rear Driver Fender Height: 41"
Front Driver Fender Height: 40"
Passenger Rear Fender Height: 40.5"
Passenger Front Fender Height: 40.5"
(these measurements were taken on my driveway which is in no way shape or form flat)
tire size is 275/60-20 and i measured them to be right at 32"
Now I also did height from the top of the tire to the fender and got:
Rear Driver: 9-1/4"
Front Driver: 9"
Rear Passenger: 9-1/4"
Front Passenger: 9"
Ok your truck sits higher than mine did on factory tires. I was just over 38" and 8" between tire and fender. Which makes me wonder if there are blocks in the rear or helper springs or something. Try lowering the front about a inch and then take a look at your cv angles. Maybe the guy before you lifted the back to the point you have to max out your tortion bars. If it does not make a difference or you dont like the look you can always put it back, but I don't think it is in your best interest to leave it there.
Just for a point of reference my bolts on the keys have about 1/4" of threads still out, barely fit the tip of my finger between the frame and the head of the bolt
Old Jan 24, 2010 | 08:31 PM
rochefort978
That is very possible.. I just got the truck in July and everyone says that it sits pretty high for a half ton (when i had it leveled before and broke the axle) I will lower it back down a bit tomorrow evening I guess I can't do it tonight. Now to get my truck "level" my drivers side bolt is just about all the way cranked and my passenger I can fit about the tip of my finger inbetween the cross-member and the bolt. Now another thing is when I had it level before when I changed the axle my shock was over-stretched & I had to use a jack on the lift to get the control arm up enough to get the shock back in.. Is it possibly lifted in the rear?
Old Jan 24, 2010 | 08:36 PM
SMKNRAM's Avatar
SMKNRAM
very possible. I agree yours does look like it sits higher than man did with 275x60x20.
look at the body lines on yours compared to mine with just cranked t-bars.
Old Jan 24, 2010 | 08:41 PM
rochefort978
What do u mean by body lines? Come to think of it.. Mine may be lifted in the back.. I see trucks like mine rollin around with leveling kits on them (or cranked t-bars idk which one) and mine just doesn't look like theirs.. Idk what could be different.. They have stock rims, I have stock rims, Tires look to be the same size between the trucks I see..
Old Jan 24, 2010 | 08:45 PM
oefootball_70's Avatar
oefootball_70
rocke'fotre I said pics about "eat it out QUICK." calm down buddy, everyone already said you were okay.
Old Jan 24, 2010 | 08:47 PM
SMKNRAM's Avatar
SMKNRAM
just compare the space between the tire and fender in the back of different trucks or get under yours and look at it. or take a picture and put it up here
Old Jan 24, 2010 | 08:57 PM
rochefort978
Yeah I got that after I thought about it for a minute but yeah I can definately see an inch or so difference. I'll run out and shoot a few pics of my rear end set-up...
Old Jan 24, 2010 | 09:35 PM
rochefort978
Here is the pics of my rear end set up.
