Just leveled the truck. CV angle opinions? pics
Old Jan 24, 2010 | 09:55 PM
  #21
cheapbeater's Avatar
cheapbeater
i always assumed your rear was lifted...
hmm... no blocks, take a pic of the end of the leaf springs... maybe you got drop shackles...
Old Jan 24, 2010 | 10:10 PM
  #22
SMKNRAM's Avatar
SMKNRAM
I will look at mine tomorrow it is dark and raining right now. I will let you know
Old Jan 24, 2010 | 10:25 PM
  #23
rochefort978's Avatar
rochefort978
Here is pics of the leafs
and for kicks and giggles here are 2 shots of the side
Old Jan 24, 2010 | 10:29 PM
  #24
cheapbeater
yup. drop shackles. 1st pic. pull those out, then level the truck.
Old Jan 24, 2010 | 10:32 PM
  #25
rochefort978
This is probably going to sound like a stupid question.. But how do I remove them? I have never messed with the rear suspension on trucks much..
Old Jan 24, 2010 | 10:43 PM
  #26
cheapbeater
unbolt them from the leafs and frame of the truck. then bolt the leafs back on to where the shackles were bolted to the frame.
wait for someone to confirm that they are indeed drop shackles... i always thought drop shackles went each end of the leafs.
Old Jan 24, 2010 | 10:49 PM
  #27
rochefort978
Well that doesn't sound too bad.. Looks easy enough.. But doesn't it always look easy?
Old Jan 25, 2010 | 12:23 AM
  #28
cheapbeater
yeah, looks like you're gunna need a bigass torx. spray those bolts up with some penetrating oil too
Old Jan 25, 2010 | 12:25 AM
  #29
rochefort978
Yeah.. HOPEFULLY I have a torx that big laying around the garage.. and yeah PB Blaster frees anything up lol. Will I need to have it jacked up or anything when I do this? I imagine having it jacked up on jackstands but will I have to remove the shocks?
Old Jan 25, 2010 | 01:54 AM
  #30
cheapbeater
shouldnt have to remove the shocks but you will have to support the frame somehow so you can get the shackle out of there. then you will have to either lower the truck down on the spring or jack the axle up to the spring... i would suggest lowering the truck onto the spring because you might need to use the weight of the truck to compress the spring a little and line up the holes. shocks can stay on... they will keep the axel from dropping too much just in case.
but again, make sure those are indeed lift shakles... pretty sure they are..
