Time bomb..
I had my water pump replaced under waranty. While the orginal pump was going defective I run my truck out of coolant in the Rad and reserve tank, I'm positive thier still was coalant in the block and that I did not drive my truck to the point of over heating the engine.
Now Coolant is disapearing, thiers no leaks on the hose clamps. After my truck was repaired, coolant was just shy of the fill mark on the reserve tank, truck was not running when I checked.
Now coolant level in the tank is down to a est 2 litre, checking when hot or cold makes no diferance, but the Rad is full ( check when cold )
I had to add greean antifreaze to get the truck into the dealer, cooling system was flushed when water pump replaced.
What is mopar antifreaze called when you go to a parts store? I can't find the proper anti freaze for my truck. In the owners manual. all it says is use mopar antifreaze..
Every clerk I talk to is trying to sell me dexcool ( GM )
so far I'm not burning antifreaze out the EX., but I woundering if I'm gonig to have head gasket issues....
Well when you first start a motor the coolant level drops in the rad until you fill it all the way, maybe the reserve had just enough to fill your rad back up? I prolly sound like a dumbass but I helped change a rad on a caddy few years back and when he filled the rad full he started the motor and the level dropped and he added more.
when the engine is not running, coolant returns to the resrve tank, when the engine is running, coolant is circulating threw the block, water pump and the Rad.
THiers allways coolant in the Rad, but, less and less in the reserve tank, it has only been four days since the water pump was repalced, I would think ( and that's my fault ) that the dodge experts would have run the truck to check for leaks and replace coolant to the right level.
less and less coolant is returning to the resrve tank, I can't find coolant at any auto parts store thats the same as Dodges antifreaze, I will get to a dodge dealer and buy it thier...
Auto value in Calgary sells mopar antifreaze.
I topped up the reserve tank and so far I'm not lossing coolant, perhaps the tech at the dodge dealer was stingy on the antifreaze.
