mystery noise solved!!!!!!!!!!!!
Old Jan 24, 2010 | 10:13 PM
JOHNSN10's Avatar
JOHNSN10
Default mystery noise solved!!!!!!!!!!!!
well i killed two birds with one stone today.awhile back i posted a thread about a noise my truck was making,it sounded like 2 pieces of styrofoam rubbing together anytime i went over bumps.you guys had me check everything which i did and it didnt work.i basically gave up on it.on saturday i was installing a switch to my halo/led headlights and i took the front dash part off that goes around the steering wheel and gauges.when it was off i drilled my hole for the switch and i noticed there was a foam block behind where i drilled the hole so i left it out when putting the dash back in.i have not had any annoying noises since.take a look below and see what has made my life hell,lol the blue led switch is where it was located.one more thing-the led is on the bottom so it doesnt blind me while i drive at night.
Old Jan 24, 2010 | 10:26 PM
cheapbeater's Avatar
cheapbeater
sonofabitch i'm glad you finally figured out what that noise was. you had us all stumped
Old Jan 25, 2010 | 03:15 AM
DodgeThunder's Avatar
DodgeThunder
lol that is bloody hillarious, all that **** off just for a stupid little chunk of foam.. Awesome you figured it out and took that POS off!!
