ran out of gas?
Old Jan 26, 2010 | 11:48 PM
  #21
mcgoo89's Avatar
mcgoo89
To me, it honestly sounds and looks like you sucked up water.. Looks like its just bogging down, first thought def is water.. U sure u didn't take that thing through a crap load of water?
Old Jan 27, 2010 | 01:00 AM
  #22
draco8494's Avatar
draco8494
also have another question, shouldnt the CEL be on for misfire codes? or do we not have any? and if my throttle body was f-ed wouldnt the little light with the lightning bolt be on? lmao it is when i unplugged it and tried to start but it still didint idle..
Old Jan 27, 2010 | 08:10 AM
  #23
SMKNRAM's Avatar
SMKNRAM
yes there are misfire codes, but it seems like you have to be driving a certain speed before it throws, might be wrong but that is how mine was when I had a plug fowled. ran bad all the time but only threw the code at certain speed!
Old Jan 27, 2010 | 09:12 AM
  #24
RubberFrog's Avatar
RubberFrog
This sounds like a case for Angela Lansbury.
Old Jan 27, 2010 | 10:00 AM
  #25
matthewbeard's Avatar
matthewbeard
my old dodge when the fuel pump went out it would do the same i had to pump the pedal to get it to sputter and run. and it was showing random signs before, i believe what worked as bangin on the gas tank a bit to shake crap up and get the pump working again for a few minutes
Old Jan 27, 2010 | 11:07 PM
  #26
draco8494's Avatar
draco8494
pulled injectors and cleaned, (they werent dirty) no dirt in fuel rails whatsoever, i guess im going to try coils next, buddy of mine works at an auto place hooked it up to a scan tool and it says coils 1,5,6,8 failed to ionize? we shall see...and i also replaced batt advance said it was bad, and some1 on another thread said that could be it, but nogo
Old Jan 28, 2010 | 01:33 AM
  #27
Palm's Avatar
Palm
I hate to be a bearer of bad news and I hope this is not your problem, but I had a very similar problem almost a couple of years ago. I had taken a friend of mine home and parked in front of his house where we talked for about 10 minutes before he got out and when I cranked back up, I had the same problem you are describing. The truck was still in warranty at the time so I took it to the dealer who kept it for almost 2 weeks. First, they said that the computer was bad and was throwing the wrong codes and after they replaced that, they were able to get the proper codes allowing them to determine that it had a bent pushrod which they repaired. This just goes to show how fast things can happen for seemingly no reason. I've driven the truck many trouble free miles since that time.
Old Jan 28, 2010 | 09:26 PM
  #28
draco8494's Avatar
draco8494
yup that would suck.....lmao.....but yeah i finally got a voltmeter, and tested the coils.. supposed to be within .6-.8 ohms resistance, well 2,3,4,7 checked out good, 1,5,6,8 checked out good for about 10 sec then jumped all over the place then back to .7? i guess this would be under faulty? i allready have 4 ordered im going to order 4 more just incase (so there at the store so i can buy em if need be) but i ran the truck with the bad 4 unplugged, ran the same, then ran the good 4 unplugged n ran the same??
Old Jan 30, 2010 | 08:53 PM
  #29
draco8494's Avatar
draco8494
bumpidy i gots it fixed, explained in first post
