No relation to 3rd gen rams but I need some help
Old Jan 28, 2010 | 02:53 PM
DodgeThunder's Avatar
DodgeThunder
Yah well thats the ****ty part about new vehicles with all these computers.. Its the ecu or some bloody computer giving it the power and telling it to keep running.. theres nothing your gonna be able to do in your driveway without a computer with a dealer only program.. Except splice a switch into the power wire going to the fan, flick it on when you start the car, flick it off when you turn it off..
Old Jan 28, 2010 | 03:12 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I'd just leave it alone. It's not gonna hurt anything by running for a little after the car's shut off.
In my opinion, I think your moms just wants to drive your truck!!!!!
Old Jan 28, 2010 | 03:14 PM
Shiloh 24's Avatar
Shiloh 24
Now I'm confused, I just went and drove it around and got it heated up to the temp it usually runs at and get home, shut it off and what do I hear? Nothing the fan comes on when cold but not when warm, WTF?!
Old Jan 28, 2010 | 03:50 PM
cwboyjohnny24
The fan will also run constantly from the time you turn on the AC I beleive. I don't know if you've had warm enough weather for that, but if you turn on the AC the fan should run.
Old Jan 28, 2010 | 03:53 PM
Shiloh 24's Avatar
Shiloh 24
No definitely no AC this week as cold as it's been, I didn't even have the heater goin either. I'm at a loss, I guess we'll be makin a trip to the stealership sometime soon.
Old Jan 28, 2010 | 03:58 PM
cwboyjohnny24
Just put a switch in it.
Old Jan 28, 2010 | 06:45 PM
lxman1's Avatar
lxman1
Site Moderator
It's a GM and they are prone to electrical problems.
The PCM is not shutting off the fan. You can scan for codes, but the PCM is likely FUBAR.
Old Jan 28, 2010 | 07:21 PM
hemiguy0302's Avatar
hemiguy0302
There has to be a relay somewhere though right? Maybe that's just hung up and a new relay is all that's needed.
Old Jan 28, 2010 | 07:33 PM
cwboyjohnny24
change out the cooling fan temperature sensor.
http://www.autozone.com/autozone/cat...&parentId=63-0
If what you're saying, it's not recognizing the motor being cool or hot, that to me sounds like a thermostat issue. I wouldn't say a relay because it's getting power and turning off and on. Just my opinion.
Old Jan 30, 2010 | 03:06 AM
Shiloh 24's Avatar
Shiloh 24
Got it back from the stealership today and I think they really stuck it to her. They said one of the two fan's was bad (total effin bs cuz I watched both of em workin with the motor at idle and when it was turned off) and the main cause was some kind of resistor in the factory wiring harness. I don't know how the hell a resistor makes the fan stay on but o well. Total came out to be over 400 bucks and she was pissed, especially after they told her it was an easy fix and it took em about 40 minutes to do.
